I think it does f*ck all unless you're full racecar and the car is low as a low low thing, and you're driving on a race-track smooth surface. Otherwise the turbulence under the car is a joke anyway. I think for fuel economy you would spend more on making up a flat bottom than you would ever save in gas.
EDIT: This also completely throws out the window that Subaru spent a whole pissload of R&D on designing a bunch of aero for your car already; for example the gearbox tunnel creates a low-pressure area at the rear of the engine bay that is intended to draw air down through the intercooler and past the turbo; if you put a full under-car tray on this would probably become a high-pressure zone instead due to all the air coming in through the bonnet scoop having nowhere to go.
Amateur aero is more or less a complete waste of time on the road.
Lots of cars have them... I think they are there to keep road dirt and water out of the engine bay, rather than for any aero effect.
the idea is to have them lead to a defuser out the back, defuser needs smooth airflow to work correctly. Car needs to be low to make them work. better off getting a bigger lower front lip. not the stick on foam s*** though.
Or on rally cars stop the stones eating everything.
Not the full length of the car, though...
3 hours ago, boon said:
i
I thought he meant just the engine bay... not sure why... but yeah... for time attack type vehicles they are probably good, as long as you have a good aero guy :)
Edited by Loren
If you have a hood scoop like Subaru you should have a tray as far back as the scoop to create a vacuum to draw more air through intercooler and radiator.
My Sw20 had it right up to the frunk firewall. Probably to compliment its high level drag coefficient?
Shed built shoestring budget aero may work with no R&D, but usually just more bling?
