Hi there,
Has anyone here had any issues with logging the data for either the AVLS or AVCS systems in a gen 2 EZ30?
I am using a tactrix and Romraider but i get no data from the ECU, the timing advance value is always zero and the VVL mode is always 1.
I have had a lean code on bank 2 which is why i started to look into what might cause this, checking vac leaks etc etc and then i found this.
I suspect that for some reason i am not getting the data or... the ECU is bad.
Checked that the solenoids all have voltage, they all have reasonable ohm readings and none are bound up.
Any further pointers or suggestions welcome.
  • 1 year later...
  • Similar Content
