Fix or Dump (USA Question)
WMDeez
Just got a 2005 Legacy GT with 204k mi for $1800. Took it to a shop for an oil leak, and it turns out to have a bad headgasket and also need new axles. Mechanic reccomends I sell it off while it still runs but I already really like the car. Id like to fix it and eventually upgrade and convert it to a manual but dont know if its worth all the money and effort, considering the high mileage.
1 hour ago, Gripless said:
The ‘eventually’ part says sell it.
If you don’t have the funds to do it now then sell before it becomes a money pit.
Also doesn’t manual conversion require cert etc now, was way easier before.
Hasn't it always needed a cert because of the brake pedal swap? It has been that way for at least as long as I can remember
Thought as long as you don't touch the auto brake pedal, you can still swap and not need cert? Has something changed recently? I'm looking to get my Nissan manual swapped and was pretty sure I could get away with no cert, as there would be enough pedal clearance between brake and clutch without needing to swap the brake pedal from the factory auto one
You pretty much have to swap the auto brake pedal to manual one to fit clutch pedal for some or all the below unless you can go to LVVTA certification place and they say it’s all ok in writing.
1) it’s too close together for safe operation or fouls
2) it shares bolts or bracket with brake pedal
3) WOF will likely flag pedal of car is not automatic on next visit
4) drive shafts are swapped so while OEM are not original
5) your insurance maybe denied after an accident and they see the pedal
6) firewall is structural and weakens brake pedal mounts
7) firewall needs to be sealed so cutting and putting new holes is also red flag
8) some cars the firewall isn’t the same for auto and has less reinforcement
Do NOT try and bypass or creatively interpret LVVTA rules. Always ask and get it in writing every time.
Also any future plans or mods that go to LVVTA may cause issues.
i certed my swap a few year later when did coilovers etc. mine was pretty easy as had all OEM parts and even a template for drilling the clutch master.
  • Joker changed the title to Fix or Dump (USA Question)
  • Similar Content
