Best sounding Legacies
webup
 pl0x said:
What is that they sound different? because of the engine/heads or because of the exhaust setup?
Its the 3% extra toughness that they add at the factory. Not available aftermarket either.
Also the exhaust manifolds are slightly different in the initial sections that bolt to the head I think??
My old RS RA has to be the sweetest sounding suby i'v had by far.......god bless her awesomness where ever she might be. :'( 3" off the turbo straight back to one resonator and a 4" oval tip cut on an angle.
Cams all the way.
When I put my EJ20G/K/8 hybrid in (got V3 heads & cams) it changed the sound completely. Straight away I said it sounded like an STI.
 BC5RA']
[quote name='boostin said:
Cams all the way.
Ah yes of course.
You should remove your badges right away ;)
*Hangs head in shame....* :-[
The 2.2's sound a bit different too - mate used to have a '91 2.2 GT which had quite a different growl to the VZ I had at the time - throatier is the best word I can think of to describe it.
<waits for someone to try and tell him theres no such thing as a 2.2 GT>
 boostin']
Cams all the way.
Ah yes of course.
I have a similar mixture and it still sounds similar to what it should sound like. I think you'd have to really really really like the original sound to keep those original RS heads on :P
 MYGTB said:
how much did your rage system set you back omegah?
i only got the rage downpipes and y pipe, from there back is custom mandrill bent 3" piping with one resonator and my RPS 4.5" muffler
i think the rage stuff cost about $600?
  • 3 weeks later...
 Omegah']
have you had your system decibel tested? it sounds pretty loud from the video. also is it drowny wen cruising on the open road?
quite like the sound if my new twin turbo legacy, (bd5)
exhaust pipe discconected at the first flange after turbo-exhaust flange (exhaust was only about 1meter long if that)
i know im naughty, but i couldn't help but wonder what it would sound like
first turbo spools up quick and sounds nice and responsive - not rangi at all
second turbo kicks in and it picks up its nuts and takes off, shrrredding
