Power output
Earl
since when exactly...
if we are talking v3 onwards (as i cant comment for 1/2) im sure the GF's do just the same amount as GC's, certainly my GF (read: hatchback (for the smart buggers)) keeps up ;)
all the spec sheets i have seen says that GF's come out with the full 206kw at the engine..
I think its well understood that Auto's have less, in the order of 180 - 190kws depending on the model and year
 pappu said:
i thought the GC/GF sti were the same..
only the older (pre 97) wagons had the smaller turbo
not sure if differences in turbo were in upper years
yup the same - same engine, turbo and ecu - afaik
maybe slightly heavier but minimal difference
 Earl said:
How does the saloon put out more power than the wagon? is it just the ECU or the turbo control or cams or.... >:(
to answer this question
the manual sedan is the base model.
an auto or wagon has a detuned ecu, sometimes accompanied by a smaller turbo and different block
usually a STI model has the same output between sedan/wagon
 Disruptz said:
If the wagon was faster, they would Rally it in the wrc wouldn't they?..nuff said. :P
Sedan would be faster if you went technical with aerodynamics etc...
ermm wasnt the last subaru that was in WRC a hatch?
and completely irrelevant - arent all over manufactors usng hatchs as well?
For clarification I have a 97 wagon wrx manual import (not STI) the infomation on a UK site similar to the info given by Dirca above and also in a book called Subaru Impressa Turbo by Chris Rees says they put out less power but not why. In 97 for example for a Jap import wagon like mine it puts out 250PS in manual form but the saloon puts out 280PS. (The automatic wagon puts out 240PS). My understanding was the TD04 turbo was across the range (not STI or RA) in this year along with other changes coils, intake manifold etc. Still leaves the main question unaswered though. Is it the ECU or turbo scroll or.... :-\
 BC5RA said:
A GF is a wagon, WRC contenders use hatches mainly for their short wheelbase. In any case anything made after 2000 is bloated.
Now, that's a broad statement.
I'd hardly call 1290kg bloated...
 DPI']
Well, you would be referring to your own specialized vehicle.
Actually the new Impreza hatch (i.e. MY08) had a longer wheelbase than the previous model.
And I wouldn't say that the +2000 models are bloated. That would imply that they are carrying extra, unnecessary weight yet they seem to perform better and better every year.....
