  • Upcoming Events
    No upcoming events found
  1. General
    1. General Vehicle Discussion
      General discussion board for anything car related
      103.2k
      posts
    2. Stolen Vehicle Register
      If your missing something or have information about things lost
      4.9k
      posts
  2. Knowledge Base
    1. General FAQ (Read Only)
      Non-model specific frequently asked questions relating to Subarus. (Read Only)
      If you have something to add, contact one of the Mod team (Full List HERE)
      43
      posts
    2. 80.1k
      posts
    3. 87.7k
      posts
    4. Legal
      All things regulatory, WOFs, Standards etc
      2.9k
      posts
    5. Motorsports
      Track day and MSNZ specific discussion
      1.8k
      posts
    6. "Other" Tech Questions
      discuss anything non Subaru related, your tools or how to fix a Lawnmower in here
      649
      posts
    7. Product and service reviews
      Share your first hand experiences good or bad.
      340
      posts
  3. Regions/Events
    1. ClubSUB Events
      Only things we're involved with such as Flat-Nats
      9k
      posts
    2. Auckland/Northland
      General discussion board for all our Auckland/Northland members
      Moderator : ADIKT:
      17.9k
      posts
    3. Waikato / Bay of Plenty / Taupo
      General discussion board for all our members in the Waikato, Bay of Plenty, King Country, Taupo.
      Moderator : nztintin
      2.1k
      posts
    4. Taranaki / Whanganui
      General discussion board for the Taranaki and Whanganui areas
      25
      posts
    5. Manawatu / Wairarapa / Hawkes Bay
      This team represents the East Coast, Hawke's Bay, Manawatu, Poverty Bay, Wairarapa-Bush areas
      5.4k
      posts
    6. Wellington / Kapiti
      General discussion board for all of our Wellington and Kapiti based members.
      Moderators : Chulozumo & Sc00byd00
      10.5k
      posts
    7. Nelson Bays/Marlborough
      Topics relating to Nelson Bays/Marlborough
      Moderator: VACANT : apply within
      76
      posts
    8. Canterbury
      From Timaru to Kaikoura, the Port Hills to Mt Cook, Its all Red and Black here!
      11.7k
      posts
    9. Otago / Southland
      General discussion for all our Otago / Southland based members.
      Moderator : Tydon
      7k
      posts
    10. Outside NZ
      Post & share your international events & see who's active in your Neck of the woods
      20
      posts
  4. Classifieds
    1. Car Exchange
      Buy / Sell / Trade vehicles
      post
    2. Parts Exchange
      Buy / Sell / Trade car parts
      post
  5. ClubSUB Shop
    1. ClubSUB Shop
      The place to go for Subscription purchases/renewals, stickers, banners, t-shirts and anything else we can get our logo on.
      posts
  • Member Statistics
    8,808
    Total Members
    1,713
    Most Online
    R205GAL
    Newest Member
    R205GAL
  • Who's Online   0 Members, 1 Anonymous, 34 Guests (See full list)
    • So far they seem to have exclusive access to Subaru, Suzuki etc diagnostic tools and Subaru support (eg unlock codes).   Almost every garage I called gets parts from them in the region so they set prices.   Not all parts are actually genuine! They get cheaper parts and don’t tell you, which I found out today from their parts department. But those cheaper parts arent sold much cheaper. Not to mention the $250-375 scanning fee for diagnostic if they don’t know what the fault is already. Though services include a scan for cheaper.   Combined with nearly $250 an hour labour rate seems like they are really milking it.
    • Well turns out JavaScript is more hassle than c. Finally after a couple of days the TPMS scanner now sends a nice webpage with a sorted list of discovered sensors. So all you need to do is select which one and which number you want it save it as.   The current arbitrary limit is 16 sensors that it will learn. The c code is a single line #define sensor-count 16 to change but the JS isn’t linked so has to be manually updated at the same time. The last piece is how sensor data is sent over canbus. The plan is to send the sensor number and mac address the first time it is seen. Then just sensor number and pressure every time the sensor broadcasts data. Sensors only send data on average every 10 minutes or so. Unless they detect a leak over time or a rapid change. Once they stop they send a idle message and go to sleep about 15 minutes later.
    • Some aero updates from previous generations.
    • There have been a few places making complex gyroid mathematical shaped coolers (YouTube link) for a while. Now metal printers are cheap enough for intercoolers in more mass produced vehicles. Making water air intercoolers even more compact and efficient.     YouTube: https://www.youtube.com/watch?v=1qifd3yn9S0 intercooler: https://www.confluxtechnology.com/product/gas-liquid-heat-exchangers/water-charge-air-cooler/
    • Still working on the web side of the TPMS as need to figure out how to run scan and get feedback as scanning is a heavy load and blocks the web server while running. Will likely add a scan time for user to set rather than 5 seconds. That way you can have a 5, 10, 20, 30 second option giving time to get the sensor to wake up and start broadcasting.   Some you can just blow on, others need to be atmospheric then 20psi+ and last lot require a lot of movement. Movement ones can take the longest to wake up, eg put in a bag and spun around. Had to learn a bunch about Bluetooth packet headers to write a custom parser since the built in one decodes far more than needed for beacons like tire monitors.   Another area I’ve been looking at, is aerodynamics which other than wool tufts needs measurement. I already have some aircraft vortex generators fitted. Anything aerodynamics related costs way too much money or have very limited use. Making 8 channel sensor set doesn’t look expensive compared to to the 1-10k price for an off the shelf device. Sensors can be a mix of single point measurement or dual point(differential) ones, eg single measures absolute pressure and differential you place a tubes from the sensor to top and bottom of wing and it measure the difference.
  • Latest Products
  • Popular Contributors
    • Total Topics
    • Total Posts
