The difference between Legacy RSK B4 and B4?
  • Replies 56
Found this, its a bit hard to read but cbf tidying it up :P
GENERAL
Body type Hardtop
Drive FULL 4WD
Transmission 5MT
Displacement, cc 1994
Frame GF-BE5
Price of new car, thousands yen (Tokyo area) 2643 (~$22000)
SPECIFICATION (SPECS)
EXTERIOR
Exterior dimensions (LxWxH), mm 4605 x 1695 x 1410
Interior dimensions (LxWxH), mm 1965 x 1440 x 1155
Wheel base, mm 2650
Treads (F/R), mm 1465 / 1465
Ground clearance, mm 155
Curb vehicle weight, kg 1460
Gross vehicle weight, kg
Seating capacity, persons 5
Doors number 4
Min.turning radius, m 5.6
Fuel tank capacity, l 64
ENGINE
Engine model EJ20
Max.power (Net), kw(PS)/rpm 280 ps (205.94 kw) / 6500 rpm
Max.torque(Net), N*m(kg*m)/rpm 35.0 kg*m (343.23 N*m) / 5000 rpm
Power density 5.21
Engine type Horizontal opposition 4 cylinder DOHC16 valve twin turbo
Engine information BOXER PHASEII 2 stage twin turbo (slanted flow turbine)
Fuel system EGI (electronic gasoline injection:Multiple point injection)
Turbocharger Twin Turbo
Fuel type Unleaded premium gasoline
LEV system (Low emission vehicle) No
Compression ratio 9
Bore, mm 92
Stroke, mm 75
Final gear ratio
Fuel consumption at 10-15 modes, l/100km 8.7
Fuel consumption at 60 km/h, l/100km
CHASSIS / TRANSMISSION
Power steering Yes
Tires size, front 215/45ZR17
Tires size rear 215/45ZR17
Braking system, front Ventilated disk
Braking system, rear Ventilated disk
Suspension system, front Strut type independent suspension
Suspension system, rear Multiple link type independent suspension
EQUIPMENT
EXTERIOR EQUIPMENT
Sunroof / Moonroof Not Present
Front fog lamp Present
Rear fog lamp Not Present
Xenon headlight (Discharge lamp) Present
Projector headlight Not Present
Rear wiper Present
Front spoiler Present
Rear or roof spoiler Option
ABS (Antilock brake system) Present
TCS (Traction control system) Not Present
LSD (Limited slip differential) Present
Privacy glass Option
UV cutting glass Present
Aluminium wheel 17 inch standard
INTERIOR EQUIPMENT
Air conditioner Full automatic
Wood panel Not Present
Cruise control Not Present
Centralized door lock Present
Power window Present
Steering wheel telescopic Not Present
Steering wheel tilt Present
Leather steering wheel Present
Power front seat Not Present
Power rear seat Not Present
Leather seat Option
Falling down type rear seat Not Present
Child seat fixed with seat belt Present
Rear ELR3 point seat belt Present
Front seat pretensioner seat belt Present
Fourth limited front seat belt Present
Side impact bar Present
Airbag (Driver) Present
Airbag (Passenger) Present
Airbag (Side) Option
Audio deck AM/FM radio equipped MD player
CD-player Single equipment
Car navigation system Option
I had both a '01 Blitzen (BE5C) and a '04 V9 STi
-both had 206kw rated, but TT had 343nm while the V9 had 410nm
-the B4 weight 1479 when i weight it, V9 was 1500kg (i had a v2 RA which weight like 1160kg!!)
B4 5spd V9 6spd
B4 13-18psi boost V9 23psi boost (this is factory)
The b4 did feel faster from above 6k rpm, but was still alot slower than the sti. Plus the STi would leave it for dead in the corners and braking.
Add in the differences in suspension, steering, DCCD etc etc
You cant really compare between the 2 types of cars.
Excatly, they are two different category of car, ones a family sedan and ones a rally car for the roads :P
Hi all,
Was going to start a new thread but this one seems along the same lines.
Im very new to Subaru's in General and i've been offered a completely stock RSK.
It's blue, it's manual, it's twin turbo, it's NZ NEW and made in 2001.
Firstly, are these cars any good? I dont plan to keep it long term. Plan is to sell it straight away pretty much but hopefully enjoy it while it's on the market. (Who knows, I might even fall for it... Subaru's are very nice cars to drive from my experiences)
Secondly, what are these cars worth. I had a look on trade me and found anything from $6k - $16k... The one in question has done approx 100k's and the belts have been done.
Are there any differences from NZ New to Imported?
Being a 2001, will that make it a facelift model? (I am still awaiting pictures).
And what is this bumper? http://www.trademe.co.nz/Trade-Me-Motors/Cars/Subaru/Legacy/auction-281656485.htm
Cos that is by far the hottest looking B4 front end ever. I want it.
Thanks in advance!
 XPLOIT said:
Hi all,
Thanks in advance!
These cars are awesome, you'll enjoy it :)
The tune on a NZ new one will be different to the JDM spec one. In theory, it'll be better tuned for NZ fuel but whether that is actually true, I don't know. With an NZ spec tune, in theory it would be rated to produce less power but on NZ fuel, they're probably much the same.
How much it is worth depends on how tidy it is and whether it is stock or not. For $16k I'd be expecting it to be well modified and in excellent condition. A $6k one is likely to be high mileage and/or untidy but there are always exceptions....
I believe that is the final facelift bumper. A couple of the guys have cars with that bumper. I also believe that that bumper is only on the B4, not the GTB (so the sedan, not the wagon).
Oh, and that Legacy you found on Trademe with the bumper has been on there for AGES... like a couple of months so either there is something wrong with it or he is still asking a bit too much for it.
I like these figures
B4 curb weight: 1460kg
2010 STi weight: 1505kg
Btw, the B4 weight listed there is slighty higher than the BG GTB weight. AFIAK the weight increases each year are due to crash ratings going up. Would much rather be in a BE in an accident than my BG.
I tried to find info about this when I bought mine (2002 GTB E-tune) - it was sold as NZ-new (I'm the second owner and have the paperwork) but seems to be JDM spec based on VIN plate etc, apparently imported/complianced by Subaru NZ as a new car, 3km on the clock at first inspection according to carjam.
Anyway I never found out if they actually did retune for NZ fuel or make any other mechanical changes, so if anyone knows I'd be interested to hear what the story is. Mechanics with experience of plenty other TT Subarus have commented on how well mine goes, but whether thats evidence for an NZ retune or just within the natural variation of them I don't know.
Also, the Rev-D facelift came in mid 2001 from memory, so the one you're looking at may or may not be. Easy to tell from 4th letter of chassis code though.
Ther is a way to tell if been tuned that is quite a bit of fun.
As everyone knows, JDM cars all have 180 km/h speed cut yet many manufacturers tend not to keep this in program in NZ.
Not sure if applies to all but wifes 01 B4 is NZ new purchased in New Plymouth store and that doesn't cut out at 180.
Mine doesn't cut out an an indicated 180 [arbitrary units only on a racetrack occifer], but does cut out at an indicated ~195ish (estimated, well off the clock). Which may just be speedo overread, so if you didn't go far above an indicated 180 it may be there after all ;)
  • 8 months later...
so in reading this i have an b4 tt.blistien suspension.if i look on subaru computer thingy it will come up as b4 rsk?? haha im confussed! lol
i mite have the wrong end of the stick here.in reading am i right in saying that my b4 is rsk?? mines twin turbo with blistien suspension??haha
I've got a RSK B4 and from what i've researched it's apparently between 1400-1500kg curb weight, in saying that, mine may very well be a litle heavier than that with full leather interior.
Also trying to compare the RSK and WRX together is not logical, The RSK is a family sedan whereas the WRX is built for rally/speed so ofcourse the WRX will have more torque than the RSK and reach a top speed quicker due to short gear ratios, but having longer gear ratios it would make higher top end?
Does anyone which has the better top end? RSK or WRX?
  • 3 years later...
 pl0x said:
was wondering why you hardly ever see "RSK\'s" round
no doubt bro cause you cant tell if a B4 is a RS or RSK just by looking at it or reading its badges. youll have to look at the rego.
