Tommi Mak back in a Subaru
that was maximum attack tommi at the end, sounds like its a jdm model with an exhaust of some kind, dont know how they got it to go that fast, the spec c's of old are still faster around tsakuba
Looked a fair bit more than whatever brochure power limit the are quoting nowadays.
Still. Anything under an 8 is pretty good. Considering visibility was not the best, and track conditions appeared to be slightly damp.
Guest loren
Damp track, perfect conditions for a rally driver.
It is quite likely that whatever modifications were done to the car were bolt on changes and will end up in the STi parts catalogue. They have to field test them somehow. I doubt Bragging Rights is a sufficient business case to do bespoke chassis and engine work that is never intended to go to market. Especially for such a low volume manufacturer. All conjecture on my behalf of course.
According to reports, the vehicle used in this testing was equipped with a few significant upgrades including a larger turbocharger that normally sees duty in the Japanese R205 model and some lightweight aluminum bits
from the same page as the video
so its basically a spec C ? or is that spec C type RA - RRRRRRRRRrrrrrr
 EJ20T said:
Ive seen rumors of a spec c sedan coming out, maybe this was a development mule for this?
I would suggest that this is the most likely option, however in recent years the Spec C's havnt had more power than normal have they? I thought they were just lighter?
There are quite a few differences as I'm sure the Spec C crowd can enlighten us on to the last infinitesimal detail. Perhaps a little more power, but usually a different turbo (VF34 instead of VF30 in single scroll, VF37 instead of VF36 in twin scroll?). Suspension/ chassis geometry changes seem to feature highly. There are also the special editions; the RA-R as Nick said, and the S20x series.
 loren']
Agreed, But not for setting a benchmark on the Nordschleife.
Guest loren
 BC5RA']
if the conditions suit the driver, why not?
Guest loren
 BC5RA']
Your the racer.
Since when do damp conditions equal a faster lap?
Do you not think he would have gotten a better time on dry conditions?
Some people can only drive one way, sideways. A damp track makes that easier, so
think it's possible for such a person to drive faster on a damp track. A wet track
on the other hand will probably be slower.
So a faster time with a driver suited to Dry tarmac?
Say a Tarmac specialist rally driver?
Guest loren
 BC5RA']
no, but I can see some gravel experienced drivers going faster on damp tarmac than dry.
It might sound like crap, but some people just drive in a way that doesn't suit lot's and
lot's of grip.
EDIT: I might be talking complete sh1t.
 loren']
lot's of grip.
Not untrue. Karts are faster with some slight sideways action...but i mean very very slight. Too much grip only slows you down on corner exit and top speed.
