new motor wont run
shrug
 nt_a_foz']
[quote name='nt_a_foz said:
Have you changed the top right cam sprockets or the crank gear??
Cause they have X amount of teeth on the back to trigger the cam and crank sensor. If you have a newer or older pulley on chances are tehy will have different teeth adn the ecu wont know whats going on.
Shouldnt be this if its getting spark and fuel thow brad
good point ....actually though did the legacy have fuel and spark when we had that problem???
Just thinking aloud here, the one cam pulley that has teh teeth on for the cam sensor is the passengers inlet one, is it possible it got put on the drivers inlet insteaD? and the sensor having no teeth to read off?
It will still start with no cam sensor signal.
You sure ???
Cause i put a 2002 rev d legacy motor into a 1998 b4 and it wouldnt start cause the cam and crank had differnt number of teeth, causing it to not start.
But in saying that changed them both at the same time so possibly would start only with crank..
 nt_a_foz said:
You sure ???
Nah both were different toothed but if had 1 would of run lol
What sort of rpm are you towing this engine at trying to get vacuum?
Well its alive and going fukin hard. I bought a new cambelt and chucked that on, goes nuts. Got tdo5, extractors, fresh motor with steal headgaskets and all seals and etc done. Next thing after its been run for abit is putting my front mount and putting my coilovers in. Then cert. Anyone got some yellow injectors? Needa get a set and then take it for chip and tune. When funds allow i wanna get a possum link or a g3 or g4 link. Thanks everyone with ur help.
 Ichi Ban said:
Maybe the old belt was on backwards, and he needed to hook up +ve and -VE battery around the other way to make it run :)
hmmm thats a good idea! will that work? :P
 shrug said:
I did read u smart fuk, dont think im gunna lie down and take your s***. I was probally building cars well u were swimming in your daddys sacks.
Perhaps they didn't teach you proper manners in your day?
WHEN ASKING FOR HELP IT PAYS TO BE FRIENDLY AN NOT A LOOSE CANNON
good to see you solved the problem though
