Dumb Question Thread!
Jambun
 kwi_fozze said:
that's a 205 forrie engine. same ID features as v3/4/5/6. offset igniter pack, it looks identical to my old one lol.
different compression ratio to the 207, no go on sti ecu. LOTS of det. think its running a cr of 9:1 where the sti wants 8:1
So it would still be useless with my A7 ecu were I to stay down that path. Also: just realised the fozzy ecu is the better option for a single turbo conversion on a BH; same cr.
Forry engine a no-go then. :/
They just had to have the oddball ej205
That version 5 STI EJ207 is still open deck.
Edited by Rosssub
 Shaun said:
do side feed injector harnesses fit top feeds
Yep just trim the ears off the pinks/blues them as theyre upside down you will understand when you try them. They stay in fine as clip holds them in place.
 B4 I was 250T said:
Roughly how much would a leak down (sp?) test cost? Any other ways for checking for blown head gasket? Checked dipstick, no bubbles or anything on it. Compression test? Help! lol :D
Checked the radiator top tank?
Just found out that my new BP legacy has yellow springs in (to match the bilsteins). These wouldn't be factory would they? The car does ride quite harshly on NZs top quality roads, but having nothing to compare it too im abit lost. Doesnt seem any lower than stock just seems to ride very harshly for standard suspension. Would stock BH/BE legacy springs fit okay?
How long is a twin scroll dip stick? Twin scroll/standard seen here:
Can someone with twin scroll please measure their dipstick :) from here:
The standard dipstick measurements are:
454.5mm to top notch
464.5mm to F
486mm to L
503mm to base of dipstick
  • Guest locked this topic
