Same on BH from memory.. Ive programmed it on my BE. Does your drivers door beep when you hold the drivers door handle open with the door locked? If it doesnt yours may not be equipped.
thanks for the link now i know what battery i need for my key!
except i can't even unscrew the cover.. the screws all rusty and my screwdrivers destroying it. what do?
stole those pics from Reuben, should work fro Gen 2 and 3 legacys
i've done this and worked on a BG GTB, my B4 and a friends BH
  • 4 weeks later...
 Erelyes said:
The instructions later in the thread must apply to BG's cos it doesn't work for my BH
So odd, last time I tried everything in that image and it didn't work.
Something I did must have changed something because the above instructions worked great.
My ineptitude, thanks for the help!
I used this to program my Gen 4 one too :)
  • 9 months later...
Tried this on a mates BH and it didnt beep after the first step of lifting the drivers door handle for 6 seconds???
When locked it beeps if lifted.
Ideas?
its almost same as bp and forester models. remove drivers kick penal and connect white connectors, close drivers doors and double press remote key. remove white connector, and check.
in case of bp legacys the lock switch on drivers master switch has to be held, but bh legacys dont have this.
before you do reprogramming check the remote battery.
your talking about a new KEY FOB
not setting up the pin code / keyless entry for lifting the door handle method of entering the car
two different things
 JoKer']
Yea Jokers right, I want to know how to set the door handle pin?
  • 1 year later...
Hi guys, I'm new to Subaru (just bought a 2002 Lancaster 6), still in discovery mode, but the more I find out, the more I love this thing...however...I've tried the procedure but seem to have failed. When it gets into "record mode", the long beep comes in, but whatever I do, nothing happens from then. It doesn't react to handle pulls, or anything, Has the process changed after 2000? As I don't have lock/unlock button (it's just a plain key) I also tried turning ignition on, or to ACC position - I don't even get the record mode then.
Any toughs?
Thanks in advance
you need that lock/unlock keyfob from factory to set the new code I am pretty sure
Plain jane DAt13 key wont get you far
  • 3 months later...
Been trying to program a new key fob on my bh all afternoon with no luck, tried following the instructions above, new battery and 3 remotes and nothing seems to register the key to the car. Any ideas would be much appreciated. Car beeps when handle is pulled but i cant set the code without a key being programmed to the car :/
Did this last night. Worked great, now can open the car without a key!! Only had to do it twice as I ended up not reading through it completely the first time.
  • 4 months later...
SilverRsk did you have any luck getting your new key fob to work? I have a BH as well with the OEM fob but the battery went flat in it and with a new battery does not seem to work but when I follow the procedures above the lock open closes when I press the button twice but the fob has 2 buttons so I'm not sure where to go with it....
From workshop manual:
REPLACEMENT
1. TRANSMITTER REGISTRATION
NOTE:
A maximum of 3 transmitters can be registered for
each individual vehicle.
1) Remove the side sill cover at the driver's side,
then connect the registration connectors at the
front pillar lower section.
2) Unlock the door lock.
3) Press any button of the transmitter twice to be
registered.
4) The door lock will automatically lock and unlock
in sequence. This indicates the completion of transmitter
registration for the first transmitter.
5) If registration of another transmitter is now to be
carried out, repeat procedure 3) and 4).
6) Disconnect the registration connectors after the
completion of all registration operations. After confirming
the operation of the door lock using the
newly registered transmitter(s), reinstall the side sill
cover at the driver's side.
Thanks Rosssub! I've done all that get the indication of the locks locking and unlocking but once I pull the plugs and test nothing happens which is strange...
Also it's taking more than 2 presses of the button for the locks to cycle.
I'm not sure if I should note that I have The 2 button key FOB with lock and open buttons
Yes tried both buttons and same thing takes about 4 presses of the button before it cycles locks. Might have to get another fob to test...
I've just replaced the battery but I can only try again I guess...
  • 2 months later...
