Whats the best bang for buck mods
 hijacka said:
If your getting the 4/2 pots Then best get some braided brakelines. $200.
Run decent pads and fluid.. endless offer both talk to Richard at pro sport. Wont need a bigger master.
Fuel pump is diffenatly worth the changing if this hasn't been done. I use the 400lph walbro and noticed power gains and better throttle response when i changed out the new metal geared gss341 as well as no humming noise. If anyone is interested in getting one of theses fuel pumps please let me know i will be doing a bulk buy of them and will be priced at $220 so i need numbers!.. pm me if interested guys..
You noticed increased power from a Fuel pump?
 Johnnynz']
Yes i noticed the difference, Not huge but noticeable. 500hp(255lph) vs 700hp(400lph) pump
I just don't see how it would make a difference. Unless the pump in there was on its way out and not pumping right.
Or do you mean you the previous pump wasn't meeting your needs and you retuned to suit?
Or am I way off base here?
No The previous Pump was a GSS341 and was bought new and done less than 10k.. I was suprised to have noticed the difference aswell more so top end. I really only changed it out because i was sick of the buzzing noise the 341 made. My guess is that the big plastic gearing inside the new 400lph pump uses less power due to the gearing being lighter and also bigger in diameter so higher output? theses are just guesses but there was noticeable gains.. I run a 6s ecu at the moment with a eboost2 ebc and standard vf23 turbo huge fmic and the list goes on.. but yes standard tune.
actually i too dont believe fuel pump making gains
BUT
i ahve heard from several credible mates who have seen dyno numbers jump due to better fuel pump
one of them runs a 11 sec sti and is a member here who told me that as well
so... maybe hijacka did feel the increase
BUT
Come on man, you tune cars, you know the only way you'll get a gain (without any change in the tune) is if the old pump was shagged.
60 psi at the injectors is 60 psi at the injectors, whether it came from a Walbro 255lph or an Aeromotive 1000lph, it's still the same petrol and the injector is still injecting the same amount of it. Pressure x Duty cycle = injector flow, as long as the pump can flow enough to maintain the pressure it's all the same at the end of the day.
lol i know bro
i fully know what u saying
lol im personally unsure why a pump wud make a difference but these dam 11sec sti boys and some similar 11sec evo fallaz swear by it..
strange lol..
i say walbro 255lph is more than adequete for stock gc8/gdb injectors anyway (on stock pressure)
Ok fair enough guys :P, i see where you are coming from and if you want to keep poking me with a stick then go right ahead lol i don't care if you don't believe me :'(. Seriously thou.. I'm not here to talk s*** and 1 thing i do know is car. because 1 i drive it daily and 2 i built it and maintain it myself.
No one else has ever worked on it apart from me since i bought it as a de regd wreck,
I know my car better than i know myself and i can safely say i felt improvements over the gss341. Like i said not big gains in any measurement but noticeable none the less and i'm happy with the new 700hp pump :-*.
Well in that case you must be right...
You did say keep poking :P
