What size speakers fit on the front door?
kris_pran
Gonna replace the factory ones with set of components of just speakers.... Before i opened it up what size fits on them..... Originally i was gonna put 6 and a half inch speakers on but i was told by krishna down at SSZ it wont fit..... So would 6'' fit ?? I dont wana modify anything just a straight replacement..
Cheers Guys.. :)
Yeah that's what I did in my BG, traced around the factory plastic thing onto mdf, made the inside ring larger to fit 6.5' speakers. Works well, although its a close call from the outside of the speaker to the door card.
  • 2 months later...
  • 7 months later...
Bit of a thread dredge
What size to fit the front and rears of a BH 2002 wagon?
They use a funny 3 hole setup i've not seen before, with a crappy foam cone.
You reckon a 6.5 setup will go straight in seeing as most mid-range speakers have hole drillings for africa.?
Another question. For the rears I was thinking of just installing the woofers and using a crossover to eliminate the hghs, but not installing a tweeter. Just to help with bass in the back.
remember this is just the work car. Not out to win Audio awards or throw out 130dB in the local carpark. don't want to add any extras, cut stuff up or do anything I can't reverse.
Cheers for any ideas peeps.
6.5's should fit into the factory spacers, yep. If anything you'll have to cut off the weather shield, nothing that a hacksaw or even a set of pliers can't handle.
Doing your idea for the rears will work to a point. Unless you make your own crossovers, or use one from an amp, most commercial crossovers will still have a LPF up to 5 or 6kHz, so you'll still hear singing and vocals through the rears. If you want to cut out all but mid-bass, then you want to have an LPF of about 300 / 400Hz
Ok armed with a budget of $50 and a free weekend, it was time to whip out the rattly oem's.
For most this is nothing special, but some would like the how-to.
First pull off the latch surrounds, Lift the top bit up and outwards, then the bottom unclps.
then the window switchers, come out at the top first
Then this little clip
The tweeter cover pulls off
After that just pull it out from the door. There's seven or so clips. Take it easy.
THen you are exposed to the magnificence of the clarion 30w.
I was confused about where the Cross over was hiding, there'd have to be one or the tweeters would break instantly.
oops here it is!
then time to make some surround to fit speakers that don't mount with mickey mouse ears
then to mark the drillings fit to old speakers
And all done. Time for the other 3
I got the components on sale from J-car and had a spare set of 6.5s for the rear.
Watching trade me for a double din that plays mp3's for cheap and I'll be a happy man
