Rosssub's Single Turbo Conversion.
Rosssub
Well, an interesting evening thus far....
First time I put my foot down, low revs in second gear. I got to 5000rpm, just about to change gear and heard it cut.
I initially thought my BH fuel pump wasn't keeping up and It had fuel cut. I pulled over and it was idling fine, went to drive off again and had an instant dropped cylinder under any load. Thinking plugs or coils, but I foolishly left all tools/torch etc at home.
I called a mate to grab some gear and a tow rope and come find me (half hour out of town). Popped the bonnet and had a quick look over it, coil loom plug come off on cylinder 4 because of a broken clip:
The plug pins come out the same as ECU pins. Yellow pin locking plate, popped out with a small flathead:
Then inside the plug is a small locking tab on the end of each pin. I've used the screwdriver to hold each tab in, then the pins pulled out easily by hand.
Pins pulled out, broken coil plug removed from loom. New plug installed, back on the road:
Before:
After:
I had the same coil issue, just mine was broken on the coil, cable ties fixex that. New engine has coils so, happy about that one. Oh man, I see your build and just know I dont have the patience or time to put any where near as much detail into it as you did. Really gives a standard to work towards xD
Cool, exciting times ahead for you too then. :)
I've changed spark plugs this evening. So far I've been using my original BH EJ208 plugs NGK BKR6EIX iridium. But now changing to the cooler BKR7EIX (70-100c cooler/STI heat range) before the boost gets turned up.
1300km on the new engine so far. :)
BP98 - $250.9 and rising.
Cars going in to get a downpipe made up tomorrow, nothing flash just de-catting and making it a good fit. Reusing the original Spec C bell mouth and rear flange.
Still waiting patiently for the replacement dipstick and PTP turbo blanket to arrive....
Edited by Rosssub
Had the new downpipe made up today, straight 2.5inch mild steel.
Words simply cannot describe how disappointed I am... $305 for this piece of sh*t:
I'm currently removing the turbo to fix a snapped bottom downpipe bolt, the O2 sensor has been cross threaded and wont come out. Now they want the car back again to have another go at the exhaust.
I should have spent the $300 on a cheap MIG, some pipe and done it myself...
    573.7k
