Does anyone know or can meause the height from the centre wheel to guard on factory suspension for the rear wheels? I would greatly appreciate it!
 Andy_Mac said:
Could do so this arvo since i'm still rocking nana spec. Obviously my wheel diameter is ever so slightly different to the stock wheels
Centre of the wheel to arch should be constant regardless of wheel size.
haha I seen a cop try & measure a car like that once on one of them motorway patrol things, except the other way around centre of rim to ground.....
 Andy_Mac said:
Yep. From the top inner of the rear guard to the centre of the wheel was 350mm
Thanks mate, currently have lowering springs which are the perfect height in the front but im a little low at the back (too poor for coilovers at the moment). They dropped me about 45mm down to 305mm and its a tyre rubbing party down there even with the guards rolled too :mad:. Itd be nice to find something with around 20-30mm drop to suit the look.
That's hilarious! He must not of had much luck...
Sedan springs?
 sobanoodle said:
I put it this way: are you 100% positive you have wagon specific springs? Common issue, especially with STI pinks as there is almost no way to identify them.
Im pretty sure.
Before
After Springs
 Andy_Mac said:
Have you considered getting saggy butt spacers? Would probably even it up quite nicely
Hi Andy,
I've been looking for something exactly like those but didn't know what they were called until now! Where would I find these?
If you check STI spring ratings sedan and wagon rears will be different. Sedan bum is ligher than wagon. Same applies to the front but not as crucial, i.e. 3.0 heavier than 2.0 hence different part numbers. Search for 41 Automotive thread re: STI springs group order, some good info there (that is if you are interested to know of course) ;)
Thinking the same as sobanoodle, just too much lower to be anything else considering it was even before the swap. From what i've seen they don't actually list the rates as being any different between 3.0/gt and wagon/sedan but there is obviously some minor difference there.
You get rid of the other rims or just have them off till you get this sorted?
I had the springs put in before the rims were put on, its just an old pic I had
  • 4 weeks later...
If anyone needs some awesome ride height for a BP5 wagon in future but cant afford coilovers id suggest the following:
Get Jamex super lows in the front
Get Tein S-Tech Street's in the back
Buy some extra cusion for the tein springs to prevent clunking when at high speeds hitting bumps
Should cost around $350-$400
The outcome looks like the below, people assumed I was running juddies but I just managed to get the perfect height with cheap gear
Edited by ToomTom
  • Similar Content
    574.7k
