Out of interest, do rolling road dynos read higher torque than the hub dynos? Just seems a lot of dyno sheets i've seen done on rolling road have quite high torque numbers.
Edited by ginganinja
Some rolling roads do read a higher torque reading wgich I guess is measured axle torque. Our dyno does that too but then decides it by diff and gearbox ratio to give engine torque
To accurately determine the torque on a rolling road requires things like accurately knowing the diameter of the tyre, because you are effectively "gearing" the power transmission to the roller.
For tuning purposes, where you only care about increase/decrease based on changes to the tune, it's not an issue. But it highlights the pointlessness of comparing dyno sheets from different dynos.
Do all dynapack dyno’s do it that way? So you’d be essentially getting wheel kw and flywheel torque on the readout?
Yes correct but remember engine torque measured at the axles after all drive train loss so same engine on a engine dyno will read higher
Yeah I know wheel power will be considerably lower than flywheel/engine power. Just never considered they would apply connection factors to give engine torque as the standard torque figure
Not a correction factor. Just means if you do it in 5th and sync rpm to hub speed then do 4th and recalibrate ratio it will read the same. Otherwise you will get different torque readings in each gear
Ahh I get ya now, so it's giving engine torque from the axles to bypass any multiplications from gear/diff ratios but doesn't attempt to give any guesstimated drivetrain loss factor to give a true figure at the engine
Correct people always ask hp at the engine. And it really doesn't matter. A 300hp car at the wheels could make 320 or 500hp at the engine all that matter is what comes out the axles
