Hi all just wondering if some one can help me out I've brought a 2008 sti and just wondering how to tell of it's a spec r or not it has the spec r Seats and rims just wondering if theres any other way to tell.
On 9/29/2018 at 0:22 PM, Joker said:
Applied code on the Shock tower will tell all!
ID Tag from factory is riveted there
Just a update I think its cause my is not a jdm sti as it has a 2.5 not the 2 but the Id tag doesnt actually have an applied code just a vin
Are you looking at the correct plate? There should be quite a few different sets of numbers on the plate.
If it's an import there will be a NZTA plate on the opposite tower that has just a VIN number
The cars nz new no vin on other tower it's a Fuji heavy industry's tag so I'm pretty sure its the one your both talking about I'll try to upload a pic if your really interested to see it but the original build sheet indicated it's a spec r
yep that's the one, every Subaru has that regardless of origin
has engine code & your applied model code (build code) which if you didn't have the Build sheet can tell you the same basic info
After some googleing it turns out new subarus the applied codes are on the front passenger door
I'd think that would only be the 2018+ ones. Since Fuji Heavy Industries is now Subaru Corporation.
As Joker said, it'll be on the spec plate. Usually in the engine bay, or door jam. And for newer Nissan's, under the seat.
  • Similar Content
