Thinking of upgrading the sound system in my V7. I find that my current setup doesnt cope that well. I have a JVC KW930BT headunit. I don't want to spend much so im thinking about just doing front speakers+tweeters for now.
I Went to abtec audio and they quoted me a pair of 'DD CS5' speakers with tweeters for $199.
Id like to hear what everyone else does and what I should look for.
Most of the noise comes from the floor / wheel wells, but dampening the doors does give the speakers more punch as less energy is wasted resonating / vibrating the crappy sheet metal. I did my doors and noticed a good increase in sound from the speakers, it has however highlighted just how much noise comes from the floor / tyres tho.
I have a 2011 WRX with the premium sound system, may be a different story for older base models with paper speakers. If you want the best bang for buck then middle of the road speakers with new wiring and an amplifier should set you on the right path,running speakers off just the head unit does not even come close to reaching the potential of most speakers.
Sound deadening can be done for $140 on all doors and a days labor
  • Thanks 1
Headunit will be far better than you think those JVC units are underrated.
Speakers and mounting will make the biggest difference.
Speaker brand depends on music taste.
The more effort on the things below can make $50 speakers sound better than $500 speakers on not installed properly.
sound deadening is good and for the price @Omsin got it well worth doing. The noise is resonating bass form the door cavity. Makes a difference to exhaust drone as well. Won’t help you if you have a pitch stop mount that is too hard though.
Things to do with install:
buy and some jaycar closed cell foam to the outer door skin to stop reflections
even if you do doors fully in dynamat like stuff. Speaker cones are thin and sound does also go through them.
Newer cars have foam rings around the speakers to seal them to the plastic door trim so no bass leaks where you can’t hear it.
Speaker mount maybe as be as big as 6.5” and the newer plastic is sometimes better. Ie 2007 up speakers are in carbon fibre reinforced. Not woven pretty but mixed into the plastic.
I cut the factory speakers out and screwed new 6.5” infinity coaxial speakers in. Sounds pretty good but have underwear sub as well now
If you dynamat cut strips (or foam) to put between speakers and mounting plates as well to squash down and airtight seal things.
  • Thanks 1
Quick note, make sure whatever you stick in the doors doesn't absorb moisture, a lot of water gets in between the internal and external door skin
Yes jaycar stuff is closed cell foam so no water gets held in it.
Also mount it so the top slopes so water runs off the top edge. I cut the foam back on the top edge at 45 degrees as well to it has even less chance of water staying there.
Jaycar stuff is quite expensive for the amount you get, would pararubber have the right kind of foam?
I’ve used both. The higher cost one is far better. It’s 1-2mm or white heavy rubber/tar then foam.
One sheet will do.
Other option put cheap foam on top of leftover dynamat
Just finished this now, definitely more clear sound, maybe a bit more bass. I noticed the speakers looked pretty old and there is falling materiel coming off around the cone area. Ill probably invest in some decent speakers now.
Done a lot of research and talked to some people.
So my idea of a small upgrade of speakers is now gone.
I have a quote for the below which ill probably get:
Kenwood KMM-BT304 Head unit
Infinity Ref6030cs component speakers
Fusion EN-AM60040 amp
Soundstream SST-12 Sub with Sub box & Grill
Cabling
They will make me speaker spacers too.
All this stuff can transfer to whatever car I get next (If I sell Subaru or get a new daily) so I might as well get a decent setup.
Cabling
Infinity kappa is a step up from reference I can vouch for them
  • Thanks 1
Yeah I looked into underseat ones but I will probably go for a big one in the boot and use stretchy cords to hold it in and then just unplug it when i need the room which isnt often
1 hour ago, Gripless said:
I’ve given up on amps and underseat subs are now awesome I have the C Vega one at 40% at repco.
hmm! i have been looking into these, would they be easy to slide out if needed? like when going to the track. or do they not weigh a tonne line the sub with box haha
if it only weighs a couple of kgs I would just leave it in.
34 minutes ago, Gripless said:
15kg = Skinny vs chubby for the passenger
as for bungee cords only ever in a sedan. They don’t hold up well if you hit something
Yeh i just lost 35kg so I can afford a whole system upgrade and still be lighter :P
So how do these Vega subs actually stand up against a quality full depth one?
I've been considering something like this for a while as the large sub has been in the garage since flatnatslast year haha.
Way easier than getting a custom box made up to hug the side of the boot.
15kg is 15kg when you have another car with the same power next to you on the straight haha
cant really take up my boot as I need the room for wheelchair also, might look into the CV one or just get some decent speakers and amp them. Pretty sure I still have the OEM speakers they are Terrible
