Anyone know of anyone in the bay of plenty that can reflash an ECU? Have done a single turbo swap on my BH5D but now just needing a flash. Even have a tune that could go on but don't have a tactrix and can't figure it out [emoji28]
Sent from my SM-G991B using Tapatalk
Marky that used to be on here still does some so should be able to sort you out. I haven’t seen his listing on marketplace in a while but he probs still does them
Don't suppose you have a way of getting in contact with him?
Hit up A_J_T he’s somewhere down there and is pretty handy with that TT>ST stuff. I borrowed his tactrix a few months back but not sure if he’s still active on here though.
I’ll message you his cell number. No idea if it’s still current or not though
Yea@Marky would be the go to in your area, if you cant get hold of him let me know and i can help out remotely.
iirc i provided you with the map you mentioned. My Tactrix is being borrowed again but as mentioned if you cant get someone local let me know and I can send it your way when i get it back and help out.
  • Thanks 1
Yea[mention=15121]Marky[/mention] would be the go to in your area, if you cant get hold of him let me know and i can help out remotely.
Have sent Mark a text but haven't had a response yet. Definitely do have the tune file you've sent me and borrowed a tactrix from a mate, couldn't get anything to work whether it's because I have a Mac book or I did something wrong I don't know. If you are able to help me out when you get your cable back it would be much appreciated.
With your macbook, did you dual boot Windows for using the applications required to read and flash roms? I had to set up a dual boot setup on my macbook to be able to read roms via tactrix, assume I could write but never got that far
Not that smart with computers sadly, however that does make sense. I'll have to look into it, thanks
Yeah get a dual boot going. I've done the same as darkchief with my MacBook, some things apparently work with macos but it's an uphill battle with zero support in general so make it as simple as possible and do it the way everyone else does
Any tips on doing a dual boot?
Should be able to find what you need here for instructions, and here for Win 10 ISO to download. Follow your nose (and the instructions) and you should be able to sort it out pretty easily. All first party support here, so relatively straight forward and simple to get up and going.
