Ok so this is now the dumping ground for ideas related to water spray for intercoolers.
Looking at adding one to mine and have a few methods.
  • One wire aftermarket ecu controlled or manual switch. Cycles through zones and fixed rate.
  • mutli wire ecu controlled pumps and zones rates controlled
  • same as Sti factory off, manual, auto option. Basically same as first but wire for external button
Design that anyone can make bolt in and wire up from cheap parts
Has a few options for sprayer as well from constant full coverage to multi zone spray mist
multizone is so more evaporation time between the spray or each area
Same with pumps, I have found some fancy pulsed type and also ann option to use windscreen washer type or high pressure irrigation pumps.
Edited by Gripless
Ordered parts from aliexpress.
Basic first setup will be single or dual mist spray nozzle on same line with PWM for pump 1-10Hz. Single ECU wire.
Have parts for alternating between spray nozzles if needed but that requires small circuit or second ecu wire.
Nozzles
Metal irrigation mist nozzle are cheap and range of sizes. Have a few hole sizes coming to match pumps with. Once matched then only need the best sized ones. A set of 5 with fittings is about $15 and you only need 3-4 for big front mount. Top mount should be 1-2 only.
Pump
The pump is apparently noisy as high pressure so likely going to have to be rubber mount under the car. Pumps come in filter or in filtered and being under car makes changing pump and filter easy as you just let it leak everywhere. Pumps also self prime if under 2m head and tank is higher so maybe 0.5m head total when under car mounted. Cost likely $15-30 depending on model and if filtered. Could use the cheap plastic fuel filter that cost a few dollars from repco etc and get cheaper pump to save money. Also then you just throw filter away and don’t have to worry about damaging while cleaning etc.
Tanks
5L tanks seem easy to get, but even an old oil container would work.
Boat tanks come in 5-24L have a shutoff valve in the fuel line clip and you can remove to fill them.
Idea about making custom tanks for cheap.
Some people like things tidy or stealth so…
Just using 80mm drain pipe and capping it. Main section maybe off-cut scrap. Say the 80-100mm yellow or orange stuff in nearly 2m lengths in skip bins from buried cable yesterday.
Would fit under boot floor along width of the rear. Should still allow access to spare and tools etc.
Ends where fitting (to pump and filler) are would sit over the rear quarter drains just like the factory v11 setup. Only exposed bit would be filler and that could be a flexible neck so tucked away and pulled out past rear or car to fill so no spills.
Needs a small breather line or plate near filler to stop air getting trapped depending on final shape.
Edited by Gripless
@Andy_Mac suggested behind the bumper outside the metal car body is empty. There are loads of mount points there too. Also that it may need some surge protection.
Baffles are easy just round discs with larger bottoms hole for water and small top hole for air put on a rod before capping the pipe. Could be fancy and use fuel cell foam but that adds way more cost.
Can just use the little headlight washer caps to cover the cutout in the bumper for the filler cap to look factory. Easy to get from wreckers and already factory matched paint.
Edited by Gripless
length diameter volume (equals weight in kg when full)
1.0m 100mm 8L
1.2m 100mm 9.4L
1.0m 80mm 5L
1.2m 80mm 6L
1.0m 65mm 3.3L
1.2m 65mm 4L
More findings
100mm pipe has best range of reducers for filler end eg 100-40mm which can then have flexible hose and cap fitted.
Both 80mm and 100mm come in black for downpipes from gutters so easy to get.
Sedans could have this mounted under parcel tray so very hidden and also unlikely to get hit from loose objects sliding around. Also make filler neck easy to pull out to side of car for filling.
@Niran
Could T or + multiple sections of pipe in middle or ends to have stacked tanks of different sizes and make up 30L. More for multi-use street track cars. Could run dozens of laps with spray constantly on in cyclic pattern so always super cold intake.
Fill level
Section between stack can be clear so can see fill level and run 5L for road use.
Internal sight gauge. Have second thin clear pipe through all T and + joins top to bottom with little ball so can spot easy. Pipe keeps ball from floating into tank or out filler.
external sight gauge. Small external clear hose between two L fitttings with ball inside.
Prices
NZ prices are high, parts here $15-35 or $3-10 in AU both inc GST. So need to find so cheaper places or scrap pipe jointers etc.
Edited by Gripless
Yet more
If needs to run on regular full time pump can use a 3 port valve to have default to return water to tank. This would make sure not dead headed and reduce stress on pump. Then interval timer to switch on. Can be as simple as a timer relay 2s-2min adjustable running 3 port.
For easy adjustable standalone option, unsolder the trim pot resistor in relay and attach larger trim pot and knob near centre console. Could use dial like headlight dimmer and clip into dash etc.
  • Gripless changed the title to Anyone interested in intercooler water spray circuit, wiring and tanks?
He882fe85a1c44c149685ccb6c0fade247.jpg_2
Hydroponics pipe look good.
Thick walls and rated to hold water weight when horizontal. Flat surfaces so can drill and mount filler anywhere if you don’t get 20mm outlet end cap.
Per meter 5L or 10L which should fit behind bumper.
pipes 100x50mm or 100x100mm
end caps blank or 20mm
buy caps from China and pipe locally due to shipping.
Edited by Gripless
Might be just easier in pressure pvc, as plenty of reducers and male/female threaded parts available, most merchants will sell per metre. Alot cheaper if you know a plumber ?. Schedule 80 pvc is another option but dearer but can be drilled and taped due to the thickness of the wall. Cpc,abs hdpe are all readily available.
  • Thanks 1
wanna pop up ya Shopping list?
I don't want one but just for funsies
& Yeah "back in the day" Garden watering" squirters were popular DIY alternative
Evos all had OEM sprayers so I never had my own, but rigged up plenty of washer pumps to garden 4mm plastic irrigation misters on gtir, vr4 and random Nissans.
Evo is same as Sti near handbrake so you tap the button before downshift and passing.
Don’t have a full list yet, but it’s just simple parts..
pumps anything high pressure 70-140psi are common and around $30
AEM water Meth just uses a diaphragm irrigation pump and similar nozzles as below.
https://www.trademe.co.nz/a/motors/boats-marine/parts-accessories/pumps-tanks/listing/4233911838
For stand-alone just need something like the OEM one  https://www.hella.co.nz/en/products/relays-flashers/time-control-relays/ there are adjustable versions from 0.2s upwards and you can put them in series to make patterns.
Nozzles are just 6mm mist in a few sizes like https://www.aliexpress.com/item/1005004136903055.html
can mount them in 6mm hole in the factory plastic under bonnet to intercooler duct.
plus they claim the line as designed for high pressure. Likely run the hard black irrigation 6mm line for everything except the short bit between body and hood where more flexible clear line would be better.
3 port for nozzle select or turn to tank on normal full time pump https://www.aliexpress.com/item/1005005197895762.html
Tanks turned out to be the expensive part.
Have to pull boot apart and measure up size in there.
Luckily my bumper is all chopped up so can just see the mounts so can measure all that tomorrow.
Edited by Gripless
  • Thanks 1
Measured boot and there is F all space in there.
The spare tire limits middle to almost nothing.
Chassis rails limit height to 60mm
Biggest areas 60x150x330mm on each side.
behind bumper is around 150x100x900mm 100mm is due to some bolts and the body seams higher up.
so rear bumper tank could be workable.
One pump while makes ok pressure the pulsing can cause cavitation and if air builds up on spray side of pump it won’t pull in more from tank side. So that one is useless if the line if fatter than 2mm ID as then bubbles can collect at bends unless pump is lowest point.
For those with canbus aftermarket ecu
https://www.aliexpress.com/item/1005004213766448.html
and any canbus module
https://www.aliexpress.com/item/1005003450161614.html
Or
https://www.aliexpress.com/item/32757441080.html
esp32 has canbus controller built in so only need the transceiver that does the physical connection. Arduino needs a controller like mcp2515 plus transceiver.
Could be programmed for different operations modes.
ecu sends time to run in seconds
unit automatically runs cycles until time is up
ecu sends on
unit runs single cycle
Ecu sends start and stop
unit runs until stop received
ecu send target intake temp
unkt runs, then waits 3 second, requests temp, repeats until temp under target or stops after 10 cycles
Ecu sends status request
unit send running, idle, even water low if senor hooked up. Could be flow meter inline rather than water sensor in tank. If last run had no flow assume water low/empty.
Diag options if unit is idle ecu can request
relay # on for X seconds
relay # cycle on of at x hz for x seconds
Relay # current state. Use with above or should be off
Water level low sensor current state
Water flow meter current reading. Need to turn on or cycle relay for pump using above.
CPU usage
Memory usage
CPU temp
Board temp
Even Wifi status if those are used. could run wifi AP with webpage showing connections and status of each part of unit and connected pump.
canbus dumb version have to trigger each relay.
More suited to meth or extra pump control etc.
https://www.aliexpress.com/item/1005005510819149.html
Alternative dumb single wire for button. You trigger input1 that runs 10 seconds triggers input2 input3 which run pump and solenoids in pattern as required.
single press with can run a single cycle.
input4 could run different or longer pattern. Or turn in intercooler fan when handbrake is on.
https://www.aliexpress.com/item/4000273267216.html
Edited by Gripless
Have worked out canbus code byte values.
Only thing it needs to have hard coded is ID and the ID to listen for the intake air temp for auto mode.
Auto to intake temp needs high and low byte as second byte would be target temp.
Relay cycling has to be preset number or needs high and low bytes so can set default to 10. Since the idea is just to get it to click so you can tell if relay is dead.
4 relays can do
Any 1 of 4 zones but spray is on/off by pump
advatange is more zones,
disadvantage spray comes on slow as pump builds pressure at start and drops at end so wastes a small amount of water each time. No delay between zone spray, just one after the other.
or
Any 1 of 3 zones and pulsed by solenoid that return water to tank or before pump until need.
disadvantage less zones. Pump still runs full time.
advantage build up and cut off are instant from solenoid so zero drip waste. Can program in more delay between zones so has longer evaporation time. More cooling less water.
esp32 can have wifi updates to code so could be DIY setup even on car without access to usb or serial connector.
Could preset the canbus ID to a default ID in a known range based on ecu like link, Emtron motec etc.
Needs more work, but initial syntax in single byte messages
missing
  • Startup code to announce IC spray unit is working and ready
  • A way to return zone count
  • Some operational error for water level and flow rate returned values (eg count over what time period, units to be converted to/from)
  • possibly a few generic setup codes and hardware buttons.
    • Way to set canbus ID externally but cant exactly have 11 switches to set it.
    • send packet with configured ID when a button on the board pressed so you can see the ID in a capture.
Requests codes -> possible replies
Diagnostic codes start with 0
10###### External Hardware
Used to test physical connections eg cycle would create audible clicking from a relay
11###### Internal ESP32 Hardware
Mostly useless but can log if think there are issues
Operational codes start with 0
00###### Manual triggered
01###### Automatic (must pass canbus ID for temp as next packet)
Anyone feel free to copy this and build your own version for non commercial use.
Edited by Gripless
This may be simple for you in your field but this seems way too techy for me.
ECU control is nice but could you not have some form of super basic controller with a contact thermometer on the backside of the intercooler outlet to let you know if temp is getting up and then have it run for a max amount of time and then shut off
Very nice.
Used plenty of windscreen washers in bumpers before but those save the pissing about with a needle/pin to rotate the jet up and almost closed.
Even on lower lip their low profile still looks good so could run 4 if you wanted.
Nothing stopping reusing the headlight popup nozzles either so they would lower from top down towards middle of intercooler.
Yes the basic one based on relays in that fuse box could be attached to a temp switch rather than a button.
EDIT:
Ok look at pretty diagram a few posts below for what this loooooog text looks like.
or
there are 4 relay timers that would stop the system running constantly until temp is low.
https://www.aliexpress.com/item/1005004681220191.html
Idea would be to have temperature switch trigger relays eg
connections
Unit power to 12v and ground.
temperature sensor connected to NC output of relay 2, and then relay 2 common to input 1
relay 1 NO output is connected to input 2,3,4
relay 3 NO output is pump
relay 4 NO output is solenoid if you want that
relay 1,3,4 common are 12v battery via fuse or fuses see below.
Working
Temp switch triggers input 1 and then that would trigger input2,3,4
relay 2 then disconnects input 1 since NC becomes open for a time so waits for water to have effect, otherwise it runs nonstop until temp drops.
relay 3 runs pump
relay 4 opens solenoid to allow water to jets or just does nothing.
fuses
Relay 1 only drives other relays, and relay 4 is solenoid so 3w. Pump is whatever wattage but likely higher than others.
timers
1 just 1 second as just sets off others
2 time to wait before checking temp sensor again
3 pump run time should be shorter than timer 2
4 solenoid depending on how connected to pump or ignored.
would be best to also add switch between temp switch (or unit power) to cabin so you can choose if the system is on or off.
Just have to find a temperature switch in the range you want. They are common items for HVAC and for thermo fans in cars so plenty to choose from.
just for anyone in future. Relays with 5 pins
2 pins are to coil that switches the below.
NO is relay that tab that is normally and open circuit or disconnect until relay is active.
NC is opposite to NO, so circuit is connected until relay triggered.
Common is what NO and NC connect to. Can be 12v or ground or whatever you connect to it.
Edited by Gripless
Picture is worth 1000 words so check posts below
Pump depends on the jets you use:
windscreen or headlight washers are lower pressure
mist and irrigation are higher pressure
Hose needs to fit and hold pressure of:
pump
nozzles
Tee pieces
one way valve. Needed for washer and high flow irrigation nozzles. Irrigation no drip while not one way do the same.
MSword is slightly better than MSpaint
Things in drawing are:
Temperature switch, pump, solenoid.
4 Channel relay timer
Battery
Piping not shown
I'd add:
an indicator flasher relay between the solenoid and relay 4 NO connection for best efficiency and water savings.
Also fuses should go between battery and relay common for relay 1,3,4 based on cable and device size.
Heat-shrink and terminal fittings rather than bare wires etc
Solenoid can either
sit directly after pump and recirculate water back before pump
or
Sit between nozzles (or nozzle pairs if you run 4) so it alternates left/right or top/bottom for longer evaporation time
Edited by Gripless
Universal 3 Way Blade Fuse Holder Box with Spade Terminals and Fuse, 5 Pin 25A Relay for Truck, RV, Boat, Trailer
This would work 3 fuses, and flasher relays do come in the same footprint as these common relays just dont need all 5 connections. They run 2-4 depending on type.
