OLD Dyno Leaderboard Top Twenty
  • Replies 339
Mine..from way back in 2005 when Andre from Speedtech tuned the car on the Chequered flag dyno.
Make : Subaru
Model : Impreza STI v2
Year: 1996
Name of Dyno : Chequered Flag Dynapack
Date of run : 08/07/05
Stock motor, TD05, 550cc injectors, tuned equal length headers, 3" exhaust, Apexi Power FC and Apexi boost controller.
@18psi
@15psi
Boost graphs for both
 RAC']
[quote name='boostcut said:
that is a mighty king effort.... new leader!!!!
Maybe second ?
Top on pump gas if I read correctly elsewhere your running Force 10 from Gull?
Silencr runs c16.
 subout said:
Ej257 plus holset ftw. Well done again matey
Thanks.
Yep Gull force 10 only.
I did see 357kw atw for a split sec but that was when the wastegate diaphram slit at 6k rpm :o
Make : Subaru
Model : Standard Impreza Wrx
Year: 1998
Name of Dyno : Total Performance Hamilton
Date of run : 04-05-09
144kw at 9psi
I think this is a good starting point. I have since installed a hks evc so and upped to boost to 16psi so will have to get it re-done when i get some spare cash.
would be happy to get 160kw
 RAC']
Thanks.
Coming to join you Holset boys too now, will see how they go on 2.0lts :). Dont think ill be catching you anytime soon RAC. Well done tho.
Looks like I just lost top legacy too, better get A into G.
 PhatRS']
Thanks.
get a 2.5 you softy, need to unleash the holset........... :P
 subout']
Thanks.
Eat my rev limit haha.
Guest STiEVO
Got my car Dyno tuned again at NZEFI and managed 224.2kw, not bad for the reletivly cheap mods. My legacy goes good now ;D
Subaru legacy BG5 1994
Forged sti v3 motor.
TD-05 with straight inlet
800cc yellow injectors
walbro fuel pump
twisted turbo
FMIC
3" exhaust
Possum link running 21psi
************ is this flywheel if so what does it convert to @ the wheels****************
Guest STiEVO
 boostcut said:
take away about 15 % i think bro.
so approx 30 kw difference interesting.
i ran a 196kw@w at total performance .cant post dyno as i use PS3 to get on here . i can fax it though.
Very nice rac. What turbo are you running now? See you went and saw good old mark? How is he? I havent seen him for a couple of years.
Yeah my result was on c16 but i have made over 350kw atw on 98 pump gas also. ;)
Mark's setup next door to my work so its very easy, i've just been using his dyno, he's doing good. The turbo is a holset hx35/40, about the same size as a 1.06 35r just a little bit smaller.
Just to be a pain in the but.
A little update, this will be the last for a long time as the cars going back to 4wd, i don't want anymore power for now.
What mods for that result, i would be carefull around 4250rpm with over 13:1 afr and 18psi.
The hole lots a bit lean for my liking really, did they say if there was any knock?
