OLD Dyno Leaderboard Top Twenty
  • Replies 339
AFAIK
TCF is the torque correction factor. It converts from the wheels to the flywheel torque.
If its set to 1 then there is no correction so its measuring at the hubs. Presumably you could only "fool" the at the engine figures ?
There are other ways to get "good" dyno figures as well.
yes..
simply by altering the "ratio" figure will make the figures go all over the show.
Rick (ichi) started explaining this to me the other night but i glazed over pretty quick,
*waits for him to come and explain properly*
Yes you can twist your dyno reading, anyone remember MR X's 301 KW std (ish) Imprezza lol.
198KW @ 18psi Ver 5 STi Type R
FMIC, New Fuel pump and Reg, 3in from turbo back exhaust, Link+G2. No dyno sheet available, but for those interested.
 dubbedup said:
Make :Subaru
Model :Wrx V1
Year:1993
Name of Dyno :Apet
Date of run :10/04/09
Kwatw: 177
Will post dyno sheet up when at work (cant scan at home)
Lol i should post my dyno sheet from Apet this morning. I make 316Nm of torque from 1500rpm all the way to the limiter. FROM A NA 2.2L!!! this has to be some kind of record!
I'm a little suspicious of his dyno readings today.
 forhire']
[quote name='dubbedup said:
Make :Subaru
Model :Wrx V1
Year:1993
Name of Dyno :Apet
Kwatw: 177
76kw wasn't it?, yeah he had probs with the dyno early on, i think its about right tho as have done some more mods since the last time i was there and got a slightly higher KW reading.
78kw actually!!!! that works out just up on factory spec for a 2.2, maybe a 5kw gain with the exhaust and stuff i've put on. its just the torque delivery and shape of my graph which made me a little sus on the accuracy.
Yeah he had a hard drive issue with the computer running the dyno before he even got started, his brother got it worked out so he could use his laptop with the appropriate files copied to it.
I buggered off after my run cos i had places to be, i ran second and made a early exit.
yeah i dont think torque is converted to flywheel measure, http://www.clubsub.org.nz/forum/index.php?topic=1835.msg19136#msg19136 my torque is 700nm+
Yeah i realise it's un-corrected at the wheels, as is the Kw. It's just that the graph shows a virtually flat torque curve. i produce the same torque at 1500 rpm, as i do at 4500rpm.
I figured it would have some shape (curve) and not be constant through the rev's :-\
Thats because you don't have a turbo to bump the torque up as boost raises, meaning no lump.
Guest Fastfour
 THUNDA said:
It would cost more than my car is worth to put it on a dyno but it will still strip SILNCR thts for sure HA
Tui!
  • 3 weeks later...
look slike i qualify to get on here now :-)
Make : Subaru
Model : WRX
Year: 1996
Name of Dyno : Total Performance Hamilton
Date of run :29/04/09
the best run was 167kw at 14.5psi :-)
mods: sti-ra ecu, td05 turbo, external wastegate, adjustable fuel pressure. also still had the catylic converter(175,000kms) fitted so fairly restricted, guy told me my numbers are very good for what it is.
Almost looks like clunts tune.
My GT was misfiring and backfiring and many other kinds of firing and had a nicer curve than that
yea the guy said it was the sti ecu thats putting all those bumps in the curve, been told i need a link or similar. still tho cant complain really for a wrx with all standard parts.
 driftrex']
Thats pretty good. I was doin 167kw with a link and fully forged but a stuffed vf22.
Be interesting to see now i can twice the amount of boost.
 Swindog']
yea im pretty happy with it ay, this was just to get a base reading before i go putting my goodies on :-)
Got my car Dyno tuned again at NZEFI and managed 224.2kw, not bad for the reletivly cheap mods. My legacy goes good now ;D
Subaru legacy BG5 1994
Forged sti v3 motor.
TD-05 with straight inlet
800cc yellow injectors
walbro fuel pump
twisted turbo
FMIC
3" exhaust
Possum link running 21psi
  • 3 weeks later...
Make : Subaru
Model : WRX STI
Engine : ej257
Turbo : Holset hx35/40
Year: 1996
Name of Dyno : Dynapack, Locked cener diff so rwd.
Date of run :26/05/2009
21ish psi boost.
 boostcut said:
have you got pics of engine/setup that gave you this power dude
I don't realy have any upto date pics but this close enough.
Mods,
EJ257 short block 100% stock.
v3 sti heads, custom cam gears, cam timing = 114deg atdc inlet and 103deg btdc exhaust.
3in exhaust,
600-300-100mm intercooler,
Autronic sm4 ecu,
Decapped sti pink injectors, end feed rails.
And about 3 years of playing with many turbos and bit.
