Dumb Question Thread!
Jambun
Dumb question but how does ones crank pulley come loose the only time it was off was when the cambelt was done 27,000kms ago.
as last night on the drive home i thought i'd run the BEB but it turned out the crank pulley bolt was on only finger tight and the crank looked like it was oval the way it was spinning .
eeeeeeeeek thats VERY BAD news.
you need to inspect the keyway (remove the crank pulley) and the crank pulley slot itself. IF its still a tight rectangle slot then do it all back up - f***ing tight and hope it spins in a harmonic manner.
might have come undone if not done up tight enough.
If the keyway is beveled out then its crank replacement time... (this is what happened to mine).
i put it in gear and lent on the power bar and brought the power bar to work just in case :P
I was told not to put it on to tight as you won't to be able to get it off otherwise i'm thinking i might go put it on tighter after reading you lock tight idea
Hey guys how's it going, recently i decided to clean my IC and found a pipe was blown off and melted it was from the secondary turbo, the wastegate on it is always shut untill opend when secondary is on boost, am i right in thinking that?
The only reason i ask is because i got another intercooler from a parts car with it's wastegate fully open would that mean when the car is on full boost it's either over boosting or getting no boost at all? . hopefully i've explained it well enough lolz
Any idea where a car alarm unit might be hidden on my wrx?
Its a Clifford alarm and i need to get the number off it to get some instructions off the net and source another remote....
Its not under the steering wheel/dash area and i cant seem to trace out where the bloody thing is....
  • Guest locked this topic
