Safe to use Redline Lightweight Shockproof
 caspros']
[quote name='funkytown said:
also what i've found in my 6mt - so swapping to the Motul gear oil (but to suit a helical front diff)
I use Motul also. Al at Macbilt sells it for $34 a litre.
tis who im gng to see about it ;)
For you it's $43 a litre
So Redline is cheaper $28+gst per US quart (946ml bottle). Standard trade price at BNT. I'm assuming Motul is also a synthetic oil - so either should do the same job. Most other oils on the market are only semi-synthetic..
Elf also do a synthetic gearbox oil, but it's expensive - even the guys at Extreme said to use Redline.
 funkytown said:
Note a 5mt and 6mt are different as the 6mt has an internal pump and if you read up on redline it says "not for use with pump applications" ;)
True, that's prob why the guys at Extreme sold me the 75W/90, instead of the 80W/90.
I used both Redline and Motul.
Redline is great, for about 1-1.5 years. As told by many other racers it ends up polishing the syncro cones therefore syncros cant grip well enough, therefore not being able to select gears very good.
I since changed to motul and after 1 year there have been no more syncro issues.
Normally Motul is around the $43 a liter for the gear FF
Why on your Mazda forum link do you say $53.00 a litre ? (Motul FF LSD Type II 1L $53.00) Or is that a different kind ?
Not sure about type 1 or 2 !
  • 1 year later...
 Ichi Ban said:
often syncros and be re bedded with a road test proceedure - (which I wont write up here !)
I can usually fix 50% of syncros without gearbox removal or dismanltled of any sort
4th syncro doesnt usually get a hard time
If you had said 2nd or 3rd the I\'d be leaning towards a gearbox out but 4th, I\'m sure is fixable
Where are you located?
Anyone on here know about this procedure? Seems 4th is the normal gear to get graunchy.
