What Turbo Kit for 02 STi Spec C
Hi all. Just brought a 02 STi Spec C and allready find myself wanting more power :P Looking to put in a bigger turbo but unsure of what one to use and what mods ill need. Looking to get 400WHP, 98 pump gas but want it solid as its my daily driver. Is this safe without doing internals? Was thinking of the below setup.
GTX3076R or FP Green (Do you guys think going with a Perrin Rotated kit is worth it or go with a bolt on?)
750cc injectors (or decap my sti's)
fuel pump
Fuel rail mod or Kit
Tune
FMIC (looks like i have a oversizes rad so dont know how ill fit this in)
MODEL: GDBB4FH UXH (V7)
ENGINE: EJ207DW4EJ
Any help would be much apriciated as this is all new to me :)
  • Replies 172
Rotated mount would most likely have to be done with that size turbo. Would be a fair bit cheaper to pay someone to custom build one too.
Fmic goes in front of the radiator so no problem there.
Internals would be a good idea for that much power.
02, is it a Version 7 or Version 8? AFAIK both were available in 2002.
I don't think the internals will be entirely reliable @ 400whp. That's 300wkw and probably 500-odd hp at the flywheel. By all accounts they're good for roughly 250wkw as a safe/everyday kinda thing.
What mods do you have already? If you haven't already, a full turbo-back exhaust and more open intake will change how it drives, drastically.
You could even get a reflash and have a safe, reliable ~220wkw without too much trouble.
The Spec C turbos are really pretty damn good turbos on a street car. Big turbos are fun but when they're only getting spooled at 4500rpm and you're shifting at 5k most of the time then you'll have a lot more fun with a setup that makes 20psi @ 3000rpm and snaps the revs from 3000-5000 before you can even think about it.
EDIT: If you're fixed on changing the turbo, check out the Blouch Dominators. They're big, built around Garrett ball-bearing cores, fit the factory position, reasonably affordable and will flow more than you'll ever need on a daily driver.
Not that it actually matters too much as the advice is still the same, just turbo / exhaust parts will be different if it's V7 (single scroll turbo) vs V8 (twin-scroll turbo).
But 250kw should be fairly easily attainable on factory turbo.
There are always threads on here about what people should do for more power, have a bit of a search around and see what you come up with.
Youll be pushing brown stuff uphill with a hot needle to get 250 at the wheels out of a std turbo unless you are planning on using e85 or better cams or a very friendly dyno. A bolt on gt3071 variant would make 250-260 pretty comfortably on pump gas with fuel + Ecu to match.
+1
Have seen td06-20g do abt 270kwatw so that could be another option
Basically
Exhaust
Fmic
Fuel pump
Chosen turbo
Good boost controller with proper external if possible
Optionally parallel rails
Retune - either look at rescaling stock afm pipe with bigger or SD mode ecu
Or link g4 type ecu to controll the avcs
Pretty much....
I'm aiming for 230-240kw@w from my V7 in a reliable, easy-to-drive daily form.
Mods list as follows:
VF34 turbo (as per a Spec C)
3" Siamese Downpipe
2.5" Cat-back exhaust
Tuned length headers
Process West top-mount intercooler
AVO Turbo intake pipe
Process West cold air intake + KN Pod
Aeromotive in-tank fuel pump
Link G4 plugin (which handles boost control)
Staying with standard injectors (565s) which will limit me to a safe amount of power for the block. Might get them decapped or replaced if it looks like I'll get another 10kw before the turbo runs out of puff but the underlying main goal is for power with factory-like reliability.
Check out my thread in the garage area for some reliable mods to do if your willing to spend some coin!
If your wanting to stay on factory internals I'd stick with factory turbo and do intake, fmic, exhaust and reflash for cheap easy power gains...
I have 300+ kw and driving it round on the street is just silly lol... 240kw will give you all the power you'll ever need on the street!
The link g4 will allow u to ditch the Maf
Hmm any reason other than that y u wNa go g4 and not reflash stock?
U can run stock in Sd mode and will be just like a g4 ish
Personally don't think any stock vf will get 240kwatw and not be pushing hot air even if gets there
Some Ppl claim different but not yet seen a proper dyno graph from a reputable place To say vf Wil get there
I hope to be corrected on that tho
3" Siamese Downpipe
Thx guys, gona take it into the shop and try and figure out whats already been done. Apparently when the last owner had it dynod it was around 230kw.
 pappu']
3" Siamese Downpipe
ive heard a few vf37/36 has hit over 240kw already bro
im sure that Bradly hit over 240kw on the vf37
