Wat is a safe boost level for my sti v6
  • Replies 69
 Razzmatazz said:
I don't think the center dash is the same as v4 had no clock or gauges just a lid ???
I'll try find it and get a picture, v4's have no gauges etc stock this one is an aftermarket lid. I'd planned on buying a V4 so I got it but didn't end up with enough money from the Pulsar so it's useless to me now lol
I wouldn't go above 18 psi I have the same car pretty much and mine was modded all,supporting mods and was at 20 psi an went bang, rod throug side of the block. Leave it at 18 it's a lot safer.
 WRXONP said:
nah stock rails stock regulator - walbro intank pump
spark plugs never shown any signs of leaning out on number 3 either
So with a fuel pump upgrade you're saying it's much safer to push the boost?
I'm thinking about getting a dyno run done in the near future to see what my afr's are like, would be happy to post results if they'd be relevant
6s ecu (assuming this is what u have) has a really good fuel map
i would never push any higher boost without a walbro (or similar) - hell i wouldnt actually even want to boost stock pressure without a fuel pump upgrade
im not saying its safe - alot of different factors can make AFR swing - especially ECT sensor and maf
I dont see the difference a larger fuel pump would make on a stock setup?
Flow rate yes but the cars only going to be able to burn as much fuel as the ecu allows it. Its not going to know it has a higher flow pump?
Plus the fact the afm will only see the same amount of air coming in so i presume it matches fuel with that air as loaded in the factory tune no matter how much flow there is?
