what can cause idle fluctuations?
scoobygt
I would tell them to get it fixed before I bought it. You drop it off to a mech to fix it will cost you a bit if it doesnt have a cel - no code. If you fix it yourself well just do a search people have spent over 1g on idle problems just replacing parts themselves.
The Idle fluctuation is generally a leak after the afm for which unmeasured air is getting in, which really could be anywhere hence the cost of repair may be high. Could be Intake manifold gaskets, A split hose or a crack plastic intake but its at anyone\'s guess. I would be checking out the plastic under manifold intake and pay special attention on the left hand side as some noob jockey may have replaced the primary turbo and split the rubber boot that goes over the turbo snout.. It could be leaking in a number of places anyway...check to see if its worst or more evident once warmed up, split Rubber, cracked plastic and small gasket leaks will generally open up more when hot.
This but yes people like you op who ask about it generally ask coz they have no idea. Then people say this, this or this and then they go about replacing everything, coils, leads, temp sensor, afm bov, vacuum lines etc and never find the problem. If you have a vented bov it only drops right off when you come off you throttle not at idle I think. Ive run a couple of vented ones in various cars and never had that problem ever.
 evowrx']
Unless you\'re venting a bov which is supposed to be re-circed such as the stock bov.(like me) and yes fozze it will be a slighty awesome duck caller gear change haha xD
 94 Leone']
No because it would be closed on idle? Its a valve not a hole. Mate put a recorder on his the other day...fuckwit
 94 Leone said:
Yeah it\'s supposed to be closed on idle, but the stoock ones are cruddy and let air in. Unless recirc\'dnand I don\'t have the pipe to do it atm lol
Tell steve murch that...Im going back to stock when it arrives as per his suggestion.
 evowrx']
Stock has to be recirc\'d.
Mine is stock and not recirc\'d ergo idle fluctuations.
If it is re-circ\'d it will be fine and you don\'t have to worry; otherwise non vacuumed air won\'t be \'holding\' it closed like if it were recirc\'d.
Make sense?
I had shithouse idle for ages, was due to deposits on the throttle body stopping the butterfly from closing completely making the idle control stuff freak out. Try hooking your toe under the gas pedal and pulling it up slightly to force the throttle to close properly.
 94 Leone']
Make sense?
No not at all.
