How to make it RWD..
dont do it unless youre prepared to replace things. trust me. welding the center diff is the hardest part. if you continue with the conversion make sure you replace the rear trailing arm bushes with either solid bushes, replace whole trailing arms that already have solid bushes or rose jointed trailing arms. good rear shocks or adjusties will help with axel tramp too
My write up is all that is needed :) you do that and you will be a/ RWD b/ still running your front shafts. BUT as you have been told more than once in this thread DONT DO IT, it is a very very good way for you to end up either dead or with a very very dead car, Subarus ( upto the BRZ) were not designed to be RWD, the rear end is not strong enough to take the full brunt of the engine, at best they were designed for about 60%, You can get a good reliable RWD setup ( look at PEDO) but expect to pay about 10k
As mentioned, great way to break shit all day long, a bog standard WRX is maybe 160kw atw, it\'s designed around having a nice split so you see maybe 40kw/axle rather than the 80kw/axle you\'ll feed it if you RWD it.
If you want to do skids, buy a Nissan.
 We are borg said:
Yup that delivers drive to the front diff, SO you keep everything as it is, front diff,front axles, so you are maybe a wee bit more legal, ( well not really as it has still be changed from "factory" )
sweet might pay to update the thread explaining this as it wasnt clear to OP :P (i wasnt too sure either)
