Knocking strut - wof issue?
 evowrx said:
Is a knocking strut a wof issue? It knocks but springs tight etc. Ill check with wof man tomorrow but just didnt get time to catch him today and Id like to pull the strut tonight if I have to.
If this was the case, v8 onwards would never get a warrant as they are bad for knocking. Both our previous V8 and our current v10 knocks. (we just regrease).
depends on type of knock i guess, I put my fronts in around wrong way (did not realise orientation was critical) and the strut way physically contacting the body/knocking
was on my fail sheet once, rear ones normal knock has existed for ages but has never been as issue, the kind of knock that can be rectified by greasing strut
 Timmah said:
And if this was poll, my vote would go to fix first then WoF and Cert. Save yourself the long run hassle.
Coz you can wof with adjusties...
Talked to the wof men yesterday he said if it passes a warrant its fine. Few warrant guys said if it knocks all good but if its obviously stuffed or leaking then fail.
 Marky said:
Yeah but most cert guys want a failled wof before you go in to get certed (on the wof failures) anyway
If that makes sense
Not really - when I got adjusties I took it straight off to get certed, was months from a WoF.
Cert guys check tons of shit the WoF guys aren\'t interested in and vice versa.
If you\'re taking a car for a cert for an engine swap they\'re not going to give a single fuck if you have a popped headlight bulb.
  • 3 weeks later...
Which ones knocking? I have a horrible knock in the front, but that\'s the half shaft hitting the chassis..
I would go over the top hat nuts with a rattle gun and just make sure they\'re all tight. Have heard of them coming loose on adjusties before, did you buy them new?
  • 2 months later...
