biggest bolt on turbo for wrx
chrisp
 lachlan said:
yeah man . they bolt right to the bottom . you might have to take 8 thou off the dipstick tho . but its not much
have a look on trade me . some make 350 hp . some up to 700
Sweet will look into it mate.
 slystiguy said:
Such a loaded question. But a td05 with an upgraded wheel might be what you are looking at... Fitment wise I think td06 is getting to the limit?
Also be prepared for lagg unless you have a fully worked engine
ok, yea il be running bigger intercooler and possum link. I have read they lagg to like you say. just wondering how much of that a proper tune will cut out.
 evowrx said:
More to spooling a turbo than an ecu.
^^ This.
Things to look into are A/M exhaust and intake systems. Front facing plenum. Cams with head work. Also the basics like the method of how the piping is done so to allow less restriction and a smoother flow. For example removing the stock flexi in the up pipe or changing to a silicone intake that removes the plastic corrugated stock part. You\'ll also need to upgrade fuel supply in most older cars
Others can fill in the finer details but this is what you can start researching
what car do u have and what current mods....
if you want a stock loccation turbo then u will be limited to any turbo that has a intake mouth of 2.5inch You can get away with slightly bigger mouth by getting a bit creative but there is possibly a 3 inch limit to that as the intake pipe under the manifold is only so big
next u will have to consider all your supporting mods for the chosen turbo (im guessing you have a target HP u wana get?)
also budgets u have to play with?
 slystiguy']
^^ This.
Yea i currently will have twisted up and down pipe set, 3inch strait through exhaust, will have aftermarket fule pump, intercooler and the possum link. And the reason im asking is i want to know what the limits are for a sti motor. What the best combination is. I like the td turbos as they are a solid turbo compared to others. Im just trying to play with combinations.
1798756_10151906119427115_925973243_n.jp
disclaimer : in no way am I implying shoddy workmanship by R\'s garage, in fact I can only see the highest quality workmanshuip and part used
it was just the first best image on the meme I could find
