Mines covered in dirt and birdshit and I have no inclination to clean it before MM :P I bet alot of you are getting your pedantic cleaning on in preparation for the big day!
yes but u dont expect to find it blocked :) and it has been away to a "specialist" and they couldnt find it :),this is what happens when u stop thinking oldskool and worry about the check engine light to much,when it came back and still had the same issue but to a lesser extent i started to think back to what would cause this, it was "hunting",thought maybe it was sucking air, so started to check back using a clear hose at each joint until i was still getting air bubbles at the tank,so looked at the parts diagram @ toyodiy.com and seen an in tank filter and then thought FARK i bet that is blocked :)
Oh well live and learn
Painted the scoop on the bh, its not perfect, still waiting on a different one to be made but its better than the primer grey, also changed teh oversized fuel rails from the black ones i was borrowing for red ones that arrived via courier today. gave it a wash and a quick vac out to.
Guest vf20/21bg5
Hahaha, i actually went in to the place that has had my car for the last month or so and started tinkering with it cause they hadnt done a few things that i had done b4 they took the engine out, so i was thr to back them up! ;) I gotcha back Te Rapa Automotive ;) ;D
nice man shuld be good when its going ;D
