Fitted bigger scoop today, Jase tuned car the other day big thanks! We got 15psi and then had problems with actuator blowing open, runs great though! and no more rough cold starts! Will take this engine to 20psi once i get actuator sorted and Jase is free. Should get even better iat with this scoop :o
Stay away from kinugawa internal adjustable billet actuators!
 evowrx said:
Bugger warranty job? Theyre meant to be pretty good with warranties. A lot of evo 4- running them as the stock seem to give issues and dont hear too many horror stories.
Nah they didn\'t understand english very well so i gave up.
When i bought it i had problems running it on the factory 6s ecu was hitting boost cut so i removed it and hooked it up to my compressor and found the wastegate arm wasn\'t moving till 22psi.. i removed the spring and cut a coil off it and tested at 15psi.. Problem is the exhaust pressure is blowing the wastegate open.
http://midnighttouge.blogspot.co.nz/2014/02/kinugawa-turbo-kando-information-update.html
NZEFI have had issues with there wastegates aswell and once changed problem fixed
 Roo']
Installed BC golds and sorted ride height. Currently sitting at 300mm front and 280mm rear..
Sounds like a good height
Pics!
Will post some tonight...
IMG]http://i1227.photobucket.com/albums/ee437/hijacka/20140429_131421_zpsa1f0d086.jpg[/img]
Thats interesting..so anymore then 15psi the kinugawa internal spring isnt copeing?? What if you adjust it? Im running the same actuator with my mse td06 and have not went past 12psi yet...
Nah im gona bin it, set the preload and it failed come tune day so i\'m done bothering around with it now, going to get a factory one on there soon so hopefully i can twist Jase arm to work some more of his magic soon. Also Roger from nzefi advised me awhile ago about these actuators giving issues spiking etc
Heres a good read bout them.
http://www.nissansilvia.com/forums/index.php?showtopic=502715&st=1980&p=6855227&#entry6855227
Could you use a twin scroll actuator? 12psi vs 8psi spring?
Te37s been sold to a mate and on his leggy! Currently looking for some 17s before i get booked in for a cert! Marc only has 1 set of sexy 17s back so no go there!
 ADIKT said:
Looks good spencer :)
How much you pay for you bc golds?
Got it off marcs race car for like $500 plus a couple clevis and a strut so owes me $800ish!
 Ninja 8)']
fu
Im looking for some good but decently priced adjusties... not sure I wanna go brand new yet
 94 Leone']
I decided when I go coilovers I\'m going to waste an exceptional amount on bilstein coilovers, so I can keep the B at the end of GT xD
BC begins with B hehe..
Give a yell if you want me to price you up a set of BC..we get pretty good discount from redline through work...even better if we can get a group buy
 ADIKT']
fu
I planned all along to go new, ended up buying near new second hand at half the price. And after a hard drive, i don\'t regret the decision whatsoever!
 Ninja 8) said:
300mm rear and 280mm front..shes a bit bouncy in the rear :P
How do you find the ride of the BCs? I\'m heavily contemplating a set and have them set on their softest as the roads in Christchurch are are nightmare. Then come gymkhana/trackday, stiffen them up for giggles.
Plus I\'m on my third pair of shocks, I miss my old lowered height and these ones are noisey after regreasing.
Called up Innovate/Subtech/Highbrook for rebuild quotes, looks like im looking at ~$3500 if all goes well, and more like 4k if the rings or cam belt etc are going to be done. Drive in/drive out kind of thing. So need ot decide exactly what I want done, and who to do it, and hopefully get it done in a month or so.
Is that with your original Version 6 EJ207, open deck block?
