  • Upcoming Events
  1. General
    1. General Vehicle Discussion
      General discussion board for anything car related
      103k
      posts
    2. Stolen Vehicle Register
      If your missing something or have information about things lost
      4.9k
      posts
  2. Knowledge Base
    1. General FAQ (Read Only)
      Non-model specific frequently asked questions relating to Subarus. (Read Only)
      If you have something to add, contact one of the Mod team (Full List HERE)
      43
      posts
    2. 80.1k
      posts
    3. 87.7k
      posts
    4. Legal
      All things regulatory, WOFs, Standards etc
      2.9k
      posts
    5. Motorsports
      Track day and MSNZ specific discussion
      1.8k
      posts
    6. "Other" Tech Questions
      discuss anything non Subaru related, your tools or how to fix a Lawnmower in here
      649
      posts
    7. Product and service reviews
      Share your first hand experiences good or bad.
      339
      posts
  3. Regions/Events
    1. ClubSUB Events
      Only things we're involved with such as Flat-Nats
      9k
      posts
    2. Auckland/Northland
      General discussion board for all our Auckland/Northland members
      Moderator : ADIKT:
      17.9k
      posts
    3. Waikato / Bay of Plenty / Taupo
      General discussion board for all our members in the Waikato, Bay of Plenty, King Country, Taupo.
      Moderator : nztintin
      2.1k
      posts
    4. Taranaki / Whanganui
      General discussion board for the Taranaki and Whanganui areas
      25
      posts
    5. Manawatu / Wairarapa / Hawkes Bay
      This team represents the East Coast, Hawke's Bay, Manawatu, Poverty Bay, Wairarapa-Bush areas
      5.4k
      posts
    6. Wellington / Kapiti
      General discussion board for all of our Wellington and Kapiti based members.
      Moderators : Chulozumo & Sc00byd00
      10.5k
      posts
    7. Nelson Bays/Marlborough
      Topics relating to Nelson Bays/Marlborough
      Moderator: VACANT : apply within
      76
      posts
    8. Canterbury
      From Timaru to Kaikoura, the Port Hills to Mt Cook, Its all Red and Black here!
      11.7k
      posts
    9. Otago / Southland
      General discussion for all our Otago / Southland based members.
      Moderator : Tydon
      7k
      posts
    10. Outside NZ
      Post & share your international events & see who's active in your Neck of the woods
      18
      posts
  4. Classifieds
    1. Car Exchange
      Buy / Sell / Trade vehicles
      post
    2. Parts Exchange
      Buy / Sell / Trade car parts
      post
  5. ClubSUB Shop
    1. ClubSUB Shop
      The place to go for Subscription purchases/renewals, stickers, banners, t-shirts and anything else we can get our logo on.
      posts
  • Member Statistics
    8,636
    Total Members
    1,713
    Most Online
    Tyuru
    Newest Member
    Tyuru
  • Who's Online   1 Member, 0 Anonymous, 46 Guests (See full list)
    • For the PopeMobile - I threw in the Alpine Headunit from my WRX into it. Definitely a step up from the Fusion.
    • Well wasted most of a day chasing an issue with chips not flashing. Desoldered parts rechecked with multimeter as seemed to be a possible short or something in the design blocking normal boot up.   I ended up tacking some wires directly to another microcontroller in the batch I have and it had same fault. Seems the older chips I got have a higher current draw than my normal programmer supports. Finally dug out an older one and got code to upload ok. re-soldered everything I removed so tomorrow I’ll try the canbus. After that I’ll build up another board and fit it into the case with LEDs and light sensor as a finished unit.   If this works I’ll order the newest 9th revision and also the power/can board for the tiny LCD screen ones.
    • Managed to finally get some more progress as parts arrived last week.   I soldered up the switching and regulator power supply using solder paste and heat plate which worked on all but one tiny chip. Solder bridged 2 pins but that was easy to clean up. I fitted both diodes backwards, one as didn’t check, the other I knew was backwards but was working off old schematic.   All voltages were good, so tomorrow I’ll add the can bus section and hopefully the micro controller.   I missed ordering the tiny capacitors for the canbus but the voltage sections are overly filtered and won’t impact testing. The static protection chip wasn’t ordered either as that want needed to test.
    • You may want to look at dielectric grease for those plugs. https://www.supercheapauto.co.nz/p/permatex-permatex-dielectric-grease-.33-oz/379868.html
    • Also note   After alot of research im now unsure of TPS is even the problem Most OBD1 Code lists show  code 31 as Throttle Position sensor fault and code 43 is 43 Accelerator Pedal Switch which is different to Throttle Position sensor fault and idle switch  fault which is 42   I just checked and double decked the ECU Pinouot for Z4 Ecu and Stock BC5 Ecu and there is no wire or input for such 43 Accelerator Pedal Switch >_ <
  • Latest Products
  • Popular Contributors
    • Total Topics
    • Total Posts
