how much power max can a GDB sti motor handle
hey guys im just wondering if anyone could tell me how much power (kw) max a gdb motor can handle
heard many stories , still unknown , can anyone help me out ?
  • Replies 115
More like 600. Those GDB's have a massive drivetrain loss due to the power take off to run the flux capacitor
Guest loren
Nos ones knows hows muchs powers yous motors cans makes. Could bes 275skws befores its blows ups?
maybes onlys 250skws. whos knows?
Guest Fastfour
Unless you put in a vortex displacement valve then I wouldnt run more than 225kw atw - you will risk melting pistons with anything higher than that.
Let me know if you want one and will post up a link
Thats like asking how long is a piece of string..
Depends on its past history, setup, tune, how its been lookedafter..
theres no "xxxkw" figure that itl crap out at..
i had 232kw on my gdb motor and it shat itself in a big way..
Others have run that figure with no problem...
You dont know how much it can handle till its to late nad its blown up hahah
Guest Fastfour
Thats because you didnt run a vortex displacement valve like I do
 Fastfour']
oh is thaat hwat i want haha...maybe i need a new one for my new motor... ;)
Guest Fastfour
Kevin,
Stop being an idiot. Your car as it is currently is way more than what you will be able to handle. Just get out onto the track and stop posting stupid topic after topic.
 R.D said:
how much better does the newer 2.5L out perform the 2.0L in handling power on stock internals?
Its weaker than the 2.0... Pistons are worse for sure - v common for ringland failure
 Qwerty']
really? shot subaru. interesting.
Guest the_return_of_the_jedi
i had a 1956 subaru back in my day, the engine was made from new alloy technology and german engineering.. the turbo was the size of a dinner plate and it would tow logs out of the kumeu forest like a hooker serving extras in a thailand strip joint, after we wound the exhaust boost up to 45 psi and the intake boost upto 300 psi it was pushing around 500 kw at the fly wheel.. we had to put sacks of sand in the boot as the bugger would launch 20 feet in the air if we tried to drag off the log skidder.. i found the seats very uncomfortable at that sort of power as it would vibrate so much and cause jarring in the hips..
as mentioned earlier by someone else the flux capacitor had to be realigned every 3 weeks due to excessive use and various technology upgrades.. i dont recommed driving faster than 260 kph in a circle tho as you may find your lunch ends up on your windscreen which can make it hard to see the boost guage on the bonnet
good luck
 pappu said:
depending on tune and condition of engine
on the street u may be able to get away with 260kw
but on the track perhaps 230
You and spec C should get together, then you'd be able to convince each other that this thread is the truth.
