Dumb Question Thread!
Jambun
hey hoping someone knowledgeable can help with this:
so I built some sweet adjustable struts for the Ace and my question is this, If I run low offset 13x7's with the stretched tyres, maximum negative camber, and maximum low, will this truly mean that:
1) I will drift like Takumi?
2) Girls will suddenly find themselves becoming a hot mess upon sighting the ace?
3) Police and government agencies will treat me like a foreign ambassador with full diplomatic immunity?
4) I will finally have the coveted yolo-swag?
Yes to all the above. Wheres the pics!?!?
 ADIKT said:
At some point when changing the suspension I split the drivers side CV boot - now I have grease on the inside of my wheel.
The split is very small and has just pierced it
Easy enough to do myself?
Yea bro easy enough if you get the correct size boot.
OK I want to fit a solid rear diff axles etc to my track car as ive uprated the motor now and the r160 wont handle it, want to stay 5 speed, have a late V8 STI wagon 5 speed which is 4.44 cant seem to find a 4.44 r1800 arse end and the closest r200 ratio is 4.36 will that difference Make any noticeable difference
 94 Leone said:
Factory 205/50R16 read 10% high, seems silly to me. I was thinking there was potentially a way to digitally recalibrate :P
If you have an electronic speedo, Jaycar sell a little bit of diy witchcraft that can use to re-calibrate the speedo.
Can't remember what the kit is called though sorry.
Yeah, it'll overheat the centre diff. Especially on the later model 5 speeds.
  • Guest locked this topic
