Dumb Question Thread!
Jambun
Cool, I\'ll YouTube this. So there\'s nothing like pads or such that need replacing? Just tighten her up and off you go?
 Johnnynz said:
Can be adjusted at the Handle end also if your at the top of your handle range.
I had it as far as the handle would go (I think) oddly enough I had it tightened almost 5k ago during a service.
 Johnnynz said:
I\'m no expert but I just adjusted my Handle, darn simple and fixed my problem.
Centre console out and if you can adjust a push bike Gearset its self explanatory.
http://www.clubsub.org.nz/forum/index.php/topic,24095.0.html
That shows a much much much better way to ensure you have a good strong handbrake. Takes bugger all time to do it properly and you could park it on a cliff after tightening it up at the back.
 Koom']
Thanks Koom! Just what I want.
 kwi_fozze said:
Sweet, now to find me some pipe that\'ll fit lol, that won\'t cost me a 3m length... Only need probs 3/4 meter of it, and a couple of bends... But to buy it in a full length f**k it\'s expensive!!!!
Surely you could ask a plumber(s) or a work site for a piece of off run they don\'t need?
Where are you running the PVC pipe to?
If the airbox is pulling air directly from the guard already then it\'s as cold as it can possibly get already, without the risk of it sucking water if you try 4x4\'ing in it
Pretty sure the factory setup (the over - the - radiator thing) on v7 onwards doesn\'t actually present any measurable restriction anyway I thought?
You lose most of the sound running the pipe down anyway, muffles it heaps.
Get one of those M&H silicon AFM pipes (they\'re like $60), leave the airbox open to the guard, sor\'ed - loud as you\'ll get it without just using a pod
The under manifold pipes make things a heap louder too don\'t they?
correct. thats what im sayin. silicone intake will get you lots of induction noise. will also make the stock BOV more audible also
 Codex said:
I\'d use wd40 for some things (works magic when trying to fix anodizing too :P) but after seeing what id does to bike chains i\'d be cautious o-o turns bike chains into rust factories lol
Ive been using it on my shitty mountain bike chain for years and years and the chain still looks brand new
  • Guest locked this topic
