Turbo question! I have a 2008 GRB and am currently thinking about getting more power out of it. My current set up:
K&N Typhoon cold air intakeFUJITSUBO 3" Cat-Back exhaust
Rage 3" downpipe
FactoryVF49 Twinscroll turbo
Factory Blue 525cc injectors
227kw on 19 psi tuned at rapid performance here in Timaru
The next stage i was thinking was: AEM 320LPH Fuel pump, 900cc injectors and a Kinugawa TD06SL2-20g turbo Possibly going FMIC at the same time. From what i've been told the factory sti up pipe and headers arn't worth upgrading at this stage?
This will be my first experience for a turbo upgrade and want to know everyone's thoughts.
Thanks!
Catback came with the car from Japan, second one i've had from them and very pleased with both. A nice noise but not too loud and in your face
To be honest, since you're after some more power, while the Kinugawas are good for factory fitment, they're still old tech.
While yes the Holsets are big turbo's, with T/S you can get really good response and very linear power curve and you'll spend the same money for one as a TD06.
You will however have to do a twisted turbo setup and go to front mount. imho, totally worth it.
Biggest issue with holset is you spend the cost of the turbo in fab and bits. Td06 in a bolt on housing thro murch be 1500 tops with all required shizl. Other option is blouch good turbo bolt on for most subarus again pricey
If you get a kinugawa one make sure you get someone local to take a look (i.e. balance check) before bolting it on. Just a suggestion.
Do you have anything to back up that advice or are you waffling ?
Kinugawa = kamak = ****ing huge oem supplier . Its not some dsr crap
I have a kinugawa td06sl2 turbine wheel bought new, direct from the online kinugawa shop. It has no damage to the item, at all, period. I personally witnessed it spun up on a balancing machine. The turbine wheel was not fitted to the shaft square so at low rpm it appears to have a wobble. The backside of the turbine wheel has been machined to balance the shaft. It is far from the same quality of manufacture of a genuine mhi turbine wheel. If you have a balance and a mhi wheel to compare against I'd gladly show you.
What do you have?
Pretty aggressive post against someone offering a suggestion and not bagging the product.
Nothing to see here.... keep scrolling.
Cats and turbos... the two most debated topics relating to hot air :P
144994d1437500194-start-all-cat_eating_t
lols. first he defends chromies... now this.
Is the cat an optional extra?
  • 1 year later...
It's the "turbo cat black" you read about on forums...
