Cobb 4 bar map sensor on its way.
Plus some other bits
1200cc injectors
colder plugs
Viton stem seals
still waiting on studs
rods and crank prices still pending as well.
  • 3 months later...
On 17/08/2019 at 6:56 PM, Gripless said:
Rods shipped less GST customs charges
Argo
EJ25
NZD $1,635
I beam
131.7mm
ARP 2000 bolts
EJ20 green list
NZD $1,160
I beam
130.5mm ?
ARP 2000 bolts + $32 ?
Both upgrade to ARP 625+ bolts + $73
Wiseco
NZD $1,385
I beam hybrid
619 grams per rod
130.5mm
ARP 2000 bolts included
On 16/08/2019 at 1:58 PM, Gripless said:
Wiseco also do a set of boostline rods which are overkill 2000+ hp rated
https://blog.wiseco.com/wisecos-new-2000hp-capable-boostline-connecting-rods
More
https://blog.boostlineproducts.com/the-engineering-and-science-behind-boostline-connecting-rods
USD$780 + shipping.
These are a stocked item for EJ series so easy to order.
Video: 900hp EJ build
On 16/08/2019 at 1:44 PM, Gripless said:
below are NZD prices at today’s exchange rate and not putting which suppliers.
ARP
11mm           ~$390
625+ 11mm ~$1009
RCM
14-12 s99 Super ~$860
14/12 s99            ~$662
On 15/08/2019 at 9:25 PM, Gripless said:
Well James Marshall Motorsport is a distributor in NZ
Billet bracket and old tensioner setup with cosworth belt kit too.
https://rogerclarkmotorsport.co.uk/store/product/745-rcm-high-grip-bracket-cosworth-timing-belt
Ok haven’t spent much time around the car and build lately but repost from the 500kw build.
 Kind of want it done mid October or I’ll run into other things I need to get sorted.
Wiseco boostline rods are top of list, as well triangles are structurally awesome (without the O)
Plus rated to 2000hp so no chance they will bend or break.
RCM 12/14mm studs means no head modification and just tapping the block out. Since that is the only soft metal there is no reason to go 14mm as s99 steel should not stretch unless the engine s***s itself.
I was going ARP but the prices are way too high for the 11mm let alone anything bigger.
More I’ve seen from overseas that pinning and line honing the crank journals is a must.
EFR7163 is here and needs to be ceramic coated then heat wrapped in alloy ceramic alloy sandwich heat shield.
Has the dual port turbosmart wastegate actuator all fitted.
GFB makes a vent to atmosphere valve for the EFR now so can keep the pssh noises.
Thinking to that I will keep the EFR boost solenoid.
Exhaust needs a bit or work still to make it straight through not quad tipped. Even though it is titanium smaller AdrenalinR one naught sound better.
Luckly I don’t have to drive to work as that pitch stop still sounds like s*** vibrating the firewall.
Intercooler is still a big unknown. Really want to go water cooler and no bonnet scoop ?? yes yes, special place in hell awaits I know.
Edited by Gripless
  • Like 4
Already have a new top mount one just sitting here.
Id anyone is interested I’m not sure I need it.
Edited by Gripless
Well that went downhill fast.
On back order ? and no ETA so guess plan to assemble sometime next month is out.
Back to thinking about pinning the mains and reboring the mains.
  • Sad 1
So wow the Wiseco Boostline rods look amazing, very happy with them. 607.0-607.5 grams
I should get some photos up with all the other parts at some stage.
If anyone is good with video work I thought about getting all the sweet parts together to video and review.
Pretty much going factory crank now with info from the 500kw topic.
sounds like I need to go beehive springs due to the higher rpm limit I want so will sell off the titanium retainers I already have.
Mine isn’t nitrided since it came from a 2009.
Plus has tiny hairline scratches. Still within spec but nicer to have the 2012 or whatever nitrided version.
You can always get a crank nitrated bud ;) seriously. Costs about $150-180 my center thrust crank is nitrated.
  • Thanks 1
So factory crank is good for 800hp or more :)
Being that is the weakest part of the build it should hold enough power to make the turbo seem tiny
Heads are booked for
CNC Big porting
+1mm valves for both intake and exhaust
bronze valve guide
fancy valve seat profile
seems I have to pin mains to use ARP car bolts since they torque higher and then line bore the main.
Edited by Gripless
39 minutes ago, Jono24 said:
Who's doing your cnc porting, kelfords? I hear Hartley now cnc port ej20 heads too.
Sent from my SM-G960F using Tapatalk
Horsepower heads which was part of kelfords.
I bought kelfords beehive springs, larger tappets, their valves and cams. Put these in my car and it didn't make a huge difference to power levels around extra 10wkw. I did have reprofiled cams before though through Franklin so didn't expect too much.
Getting the larger tappets In which hold the springs in on the valves is a bloody hard job, they are around 50% bigger than th OEM part.  I've built my own heads a number of times now and these are way harder to assemble but are worth it as they are far better at holding the valve, spring etc in place, reccomend them.
I line bored my crank too and has extra dowels In there to help hold it together.
Edited by Username
  • Thanks 1
@Username where did you get the tappets from?
@Dairusire that was an option until the below. Twice the price and brand new crank with zero wear.
OEM EJ20 nitrated crank shipped with customs is NZD$520 same as C-spec
https://partsouq.com/en/search/search?q=12200AA390
$403 shipped to NZ
https://www.customs.govt.nz/personal/duty-and-gst/whats-my-duty-estimator/
give $117
FYI...
2.5L nitrated and salt bathed
https://partsouq.com/en/search/all?q=12200AA430
Edited by Gripless
f***ing new phone without custom dictionary can’t swear or name car parts
$403 shipped to NZ
give $117
FYI...
I bought from kelford, they are described as 6 degree radius beadlocks, there were 11 bucks each not inc gst. Will be more now as all the other things I bought were, this was a year ago. They are far bigger than OEM.
I bought the same crank for mine too mo brainer , cheap really considering it's OEM.
Wish u could just insert pics in these posts the link to url is a pain in the ass.
Edited by Username
  • 3 weeks later...
Heads arrive back this week.
Can’t wait for the super shiny ness of CNC and hand polished. ?
Plus the box filled with all the other head related goodies like cams, beehive springs, titanium retainers and keepers.
New crank arrived today with some relays.
4x relay $90 shipped new form partsouq
vs
1x relay $90 from NZ new or almost the same from wreckers
WTF
Edited by Gripless
So much left to buy...
RCM head studs
RCM tensioner
waterpump with cast impeller
timing belt
ARP case bolts
Clutch
intercooling parts
forgot to add
 Fire ring head gaskets
 bearings
so much left to do...
Pin Mains and line hone crank
close deck block
oil gallery mod
Tap head stud holes for 14mm studs
Edited by Gripless
7 hours ago, Niran said:
Power doesn't come cheap does it
I think I could have saved a few thousand  on parts if I’d stepped down one level of quality and still been over built for the original power goal.
at this stage I think I have a block that would be reliable daily with 50% more power.
So a box or two arrived
220-B Cams
beehive springs
titanium retainers
shims
keepers
+1mm inconel exhaust valves
+1mm intake valves
CNC ported heads with
+1mm valve ports
CNC seat profiles
bronze valve guides
And machined surface so ultra
