Hi everyone i have a 2018 Subaru legacy  3.6 rs   which has had the sti package put on  which subaru  nz  did with new legacys as an option .
My question is i find the suspension really bouncy   i am pretty green with these things but does anyone else own one & find the suspension the same ?
Do i need to get the suspension changed to fix the problem ? if so where or who would anyone recommended in Auckland  to go to ?
I’m guessing all they did was a different spring on the standard shock. I don’t think anyone else on here has that legacy yet.
Is it a firm ride that bounces back on bumps or bouncy all the time?
Doubt there is much you can do other than changing the whole set up. May we see if Subaru dealership have any options for you?
Hi there  ,know they did nothing to the actual suspension  . they put a rear sway bar on & a flexible tower bar under the hood for the front . its a soft ride  when you go over juderbars   its very bouncy  & when on the open rd when you hit a bump its quite bouncy someone told me they changed the suspension from the model before  not sure , maybe  i will ask subaru ?  thanks for you help
from snz
https://www.subaru.co.nz/promotions/legacy-sti-experience
it's largely $5k of sti performance cosmetic bits 'n pieces.
one item that stands out as a potential cause of your bounciness is the "STI embossed supersized 19" alloy wheels and Yokohama tyres".
the snz photo shows a Yoko BluEarth A.
this is a crappy eco tyre, it has no place on a sporty car !
check the tyre pressures, wheel alignment.
gut feeling is poor tyre choice.
it's a shame to see the RS and STI badges used this way  :(
Edited by newsuba
  • Like 5
from what your saying it "too stiff"?
i usually think of bouncy as in floaty like a boat which would be worn shocks (unlikely in this scenario)
^^ THIS ^^
They're now a "badge" to denote a cosmetic upgrade. Yes, they may have been designed by the proper engineers, but gone are the days where they did a lot of the work themselves in house, to make properly special cars.
It's the latter
@ride look behind one of your wheels, what colour springs can you see there?
If the springs are black (i.e stock standard) I'd look into swapping them for some STI pinks (just what they'd shown in one of the promo photos). Wouldn't go through Subaru NZ though but rather get a set imported myself/else and installed by an independent Subaru specialist.
Yes the springs are black, very observant of you with the promo photos ,   thanks for everyone's comments  , will now have to decide what to do .
Has anyone used Subtech Subaru Mechanics in Penrose ?
Highly recommend a set of H&R springs for the Legacy.
They make a 3.6R specific set which @mlracing.co.nz can get for you.
3 hours ago, Gripless said:
Do they have a rear sway bar fitted.
If it rolls or leans to much in corners then it’s a easier fit to fit a bigger rear bar.
They upgrade the rear sway bar as part of the "STI" package.
3 hours ago, newsuba said:
a new car shouldn't be this bad ?
I agree but it'll also be down to the driver's personal taste.
I'm surprised they fit all the other suspension tick box items but not the STI pink springs.
It's not that much of a sporty car to start with and designed for comfort so fitting a fattier rsb on its own not surprisingly does sweet f all. Plus STI rsb still won't be as thick/aggressives as let's say Cusco, UR or Whiteline.
