Team,
in looking for causes for my own turbo failure i have come to the conclusion of oil starvation.
Read the following and heed the instructions / warnings when upgrading your turbos or rebuilding.
The picture in the following article can be found here - http://www.boostplanet.com/subaruoilstarvation.htm
Turbo Oil Starvation and Subaru Vehicles 11-15-07
Subaru Technical Support Bulletin (TSB) 02-97-05 included at the bottom of this page
Unexplained "oil starvation" problems are a nightmare for enthusiasts with expensive high performance aftermarket turbochargers. The last thing anybody wants to hear when their turbo is inspected is that their turbo died due to lack of oil pressure or volume.
But as sure as you are that your engine runs fine and has perfect oil pressure, some guy at the turbo shop where it was produced is even more certain that the turbo bearings burned up due to a lack of sufficient lubrication. Who is correct here? Actually both can be. It IS possible for the engine to be OK, and have no damage but the turbo to be completely ruined; we have figured it out, and so has Subaru. They have even issued a series of Technical Service Bulletins (TSB's) that explain how it happens and what to do about it.
As it turns out, there is an oil filter screen built into the factory oil feed banjo bolt at the cylinder head, and Subaru wants it either serviced regularly or removed completely in order to avoid turbocharger oil starvation and failure. Insiders we have spoken with told us of numerous and recurring turbocharger failures even on completely stock 2.5 WRX, STi, Forrester and Baja vehicles due to this problem, prompting an Official Subaru Service Bulletin in October 2007. In one reported case in Alabama, even a low mileage 05 Baja which had all its regular 3k mile oil changes at the dealership experienced a stock turbocharger failure due to this oil filter becoming plugged with sludge.
This turbo screen is not to be confused with the screen that filters the oil for the AVCS valve which does not affect turbo oil supply since it is after the "tee" that splits off the oil supply line to the turbo. The AVCS filter can also become plugged and affect the performance of the AVCS solenoid, but luckily when the AVCS filter becomes clogged there is no catastrophic failure of a $1000+ component as in the case of the turbocharger filter, just a check engine light due to the non functioning AVCS.
The turbocharger filter can be seen in the diagram below, it is marked "A"
Most drivers are not aware that they even have a turbo oil filter in their oil supply line; much less that it requires periodic cleaning with each oil change. The following is from the Service Bulletin titled "Turbocharger Oil Supply Mesh Screen #02-103-07";
"the mesh screen which is located inside the banjo bolt that secures the turbo¬charger oil supply pipe to the back of the right side cylinder head should be checked to make sure it is not clogged or restricted especially if the condition of the oil is questionable or as to when the last oil change was performed. If clogged or restricted, it will reduce or cut off the oil supply to the turbo resulting in failure. The oil supply pipe should also be checked to make sure that there are no obstructions."
Also stated in the bulletin is that this is even more critical that this filter be checked frequently when the car is "used under severe driving conditions, such as moderate to hard acceleration and engine braking on a somewhat regular basis". Any vehicle with upgraded turbocharger is most assuredly going to fall into this category.
For some time we had scratched our heads about the reason that a "perfectly running car with no engine issues" could kill a turbocharger that was installed and broken in correctly. There is finally official documentation from Subaru of this problem to support the observations that the oil supply to the turbocharger can become cut off or restricted without any damage to other parts of the engine.
We recommends REMOVING this "Turbocharger Oil Supply Mesh Screen" in all vehicles running ANY upgraded turbochargers, whether ours, or other manufacturers. The thrust bearing and oiling system in our turbochargers has very little tolerance for reduced or limited oil supply. In fact our thrust bearing and oiling system requires almost TWICE the oil volume as a small stock IHI turbocharger and although "stock" components can be OK with slightly restricted oil supply, higher performance, tighter tolerance units simply cannot withstand their oil supply being restricted. This is why it is completely possible that a slightly restricted filter will destroy your Zilla or SuperZilla or other upgraded model, but not destroy your stock turbo when installed back onto the car after the failure of the aftermarket unit. This made it not only hard in the beginning to figure this problem out, but also caused some "ill will" for customers when stock turbos were installed after a failed aftermarket unit and the stock replacement didn't immediately fail.
With this problem now fully documented and explained, we hope to reduce the number of customers (both ours and other company's) who destroy their turbos from lack of proper lubrication. At the very least we are trying to advise anyone that might read this page on how to avoid a potentially expensive problem. This is a Subaru "Warranty Item" it affects the operation of the AVCS valve and stock turbo. From our experience, this DOES NOT CARRY OVER to aftermarket turbochargers.
It is every car owner’s responsibility to check and verify that this turbo filter is either removed for aftermarket turbos, or perfectly clean for replacement with a stock unit at all times. Do not assume that since you had a "Professional Shop" or "Tuner" install your turbo that your filter has been removed or checked, most people do not even know that the filter exists! At the time of writing this, we have 4 turbos installed by VERY professional shops in our facility now with oil starvation damage.
Also, do not assume that since your turbo has not failed that you are immune to this problem, you are not!!! You might still have the filter, and have been lucky that it has not restricted oil supply "YET".
If Subaru Turbo Oil Starvation is googled more info can be found.
Normally a factory feed runs 1mm. An upgraded turbo can require 2mm or larger. The TD05/06 i will be upgrading to requires a 2.3mm feed line by way of aftermarket steel braided line and fittings or burring out the existing line.
What people dont realise is when you upgrade your turbo too you need to upgrade the feed pipe. Factory is 1mm hole. And i dear say the above is how my turbo chewed itself.
The JDM avcs heads ive seen havent had the filter things in them. But someone may have pulled them out before I got to it
Also garrett and IHI ball bearing turbos require a 0.9 - 1mm oil feed aperture. Any more and the core floods and oil gets pushed through the seals.
Journal bearing turbos require a slightly bigger oil feed aperture, 1.3mm from memory
Just pulled my banjo bolt off for the turbo feed and mine has it. Pretty dirty too. Exactly like whats in that Sub notice.
AND the feed hole was smaller than needed so had to drill out in both bolts
  • 3 months later...
I dont agree. If your new turbo is still ball bearing the stock feed with the filter removed will be fine. Iv seen more turbos die from too big oil feed than too small.
I have replaced a few legacy turbo's from lack of oil due to cloged banjo bolt filter, problem with the legacy primary turbo feed is that you need to remove the passanger cam gear and backing plate to remove the bolt. :(
  • 2 months later...
i brought a vf23 turbo apparently it blows a bit of smoke and may need a new seal kit!
can someone tell me what sort of price range i will be looking at to repair? cheers!
  • 5 weeks later...
Guest crunchy
before you change any oil feed line you need to be very sure its for the right reason,
if you have stock feed line and upgraded the turbo but still retain the stock core you dont need to change anything
plain bearing turbos normaly run a 2-2.5mm fitting with a -3an line,the reason to reduce feed to a bb unit is to try and reduce volume as pressure cant be changed.
most turbos are more than happy with just 30-40psi oil pressure.
95% of turbo damage comes from contaminated oil
Guest SPANKU
i dont think you can repair those turbo. pm crunchy, he knows everything about turbo
was the filter at the turbo end or engine end?..........guess it's in the same place for a BC5?
Its on the back of the motor. Follow the oil feed line back to the back of the motor on the primary and youll find it. Unsure where it would be for the secondary.
He is not referring to the 2nd generation Legacy.
  • 3 months later...
  • 3 weeks later...
 scottiescottiescottie said:
does this effect Gen 4's? ie 2005? anyone?
Take the banjo bolt off and see if it has a filter in it?
Does it say in that article? If not just pull the turbo oil feed banjo off and get a mirror and have a look. Some of the filters just pull out with the banjo depending. Good idea to remove if in there. Its a 5 min job.
Yes they have the filters, it will become a problem in 5 or so years when these vehicles start missing regular oil changes.
  • 1 year later...
I think my car has just done that today. Turbo has gotten considerably louder after coming home today. Sounds like bearing is failing. I do a complete oil change every 5k but it has done 200k, sooo good innings I thought. Anyone got a spare vf24??
According to the article a td05/06 needs 2-2.5 mm restrictor
Ok what I have got is nonrestrictive banjo on turbo but still have the stock oil feed line which has a 1mm supply hole.
Is it worth upgrading that hole to 2-2.5 mm or since I have a non restrictive banjo Bol on turbo, it Wil be fine
I think the banjo bolt used on the turbo oil is a water item hence free flow......
Thanks
    574.6k
