 Andy_Mac said:
probably going to get more hits for this alarm in a separate thread if its not actually a avs alarm
haha yeah your probably right, will set one up if no one comes through here
  • 1 year later...
Hi Brad,
Just got a AVS S5 installed in my 2007 Legacy GT-B Wagon. The car is the type with the proximity/keyless entry and start (no ignition key slot in the steering column) and it comes with a factory feature: Interior lights turn ON when keyless FOB is sensed. Now, with the AVS S5 integration done the alarm arms/disarms with the lock/unlock of the stock keyless remote. Sweet as.
Thing is, because of this factory option I mentioned, if I lock/arm the car and walk way then come back near it, the alarm goes off as soon as the interior light dims out. That's because, I guess, the ECU "emulates" a "door-opened" to activate the interior light therefore setting off the alarm.
Do you have a work around for this? I don't need the interior light to turn on at all if I'm not inside the car but it is there, it is factory so thought of asking you first.
Cheers!
When i had mine done the installer said these cars were an absolute pig to install into. Mine has a standard key but can only disarm/mobilise when all the doors are shut and the key not in the ignition, so you gotta hop in and start within that 45 seconds or wait for the travelling circus to finally sort their **** out get in and close all the doors. Bloody irritating but nowhere near as annoying as what yours is doing.
  • 3 weeks later...
 fabio said:
Hi Brad,
Cheers!
Hi everyone, looks like we had no notification set up for this thread, oops, fixed now. Yep, the contact at AVS is either Ben or Rachael.
Ben has talked to Fabio so hopefully it's sorted (but let us know if not). Sounds like the alarm has been wired to the door light which is common practice for most cars however because of the proximity control with this vehicle it will need to be wired to each individual door switch circuit. That will prevent the symptom from happening even with the factory setting for the interior light.
  • 5 years later...
Hey man just brought a new car car an once armed an turbo timer is activate an then run its duration of time the ignition/dash lights stay on causing it to drain the battery dead. Cheers Jordan
 What happens if you shut the turbo timer off early with the remote?
  • 1 year later...
@AVS Car Security
I brought the AVS FT-06E Gps 'FreeTrack' and it came with no instructions so have no idea where all the wires do except the black and red one lol. Do you guys keep any of this info anywhere coz I cant find anything online.
If not ill talk to the guys at StreetSoundz in wellington, I know them well.
That is lame... I use battery powered GPS units... no wires, no way to disable them... easy to hide and the batteries last for years.
Edited by Loren
Any advise on a battery powered unit?
    574.7k
