180 km/h speed cut removal
  • Replies 94
 zarnah said:
I suppose the first question any of us ask should be, why do you want to do 180km/h anyhow? do you do a lot of track work? or just want to show of to your mates, kill a few of them, and ruin a few xmas's for a couple of familys?
Agreed, hopefull hes not trying to make your sig quote come true.
hi .
This car is ONLY used for trackdays . the furthest i have driven it on road is to the dyno tune shop last week . PLUS i am NO boy racer , i get my speed fix where it is safe and legal to do so .
The only reason i want to go above 180 is i am not sure at hamptons , but i am sure at puke , i will hit the speed cut .
crap ... looks like i will have speed cut then tomorrow . (maybe not if this auckland rain keeps up !)
This car was only bought 3 months ago , so still pretty standard . but it is definately only a track car , so will be slowly modifying it as money and time allows....but mostly the money part ;D
well i am planning to attend the megameet next year ..so will definately have to get the speedcut sorted .
 Optical said:
hamptons you can hit 200+ no problems. this was covered a while back, putting a switch on the speedo signal is fine for brief stints.
if it's a dedicated track car, you should get a proper ecu for it
yeah i remember the same conversation a few months back
in my experience with v2/v3 ecu's the car misses pretty badly with an abnormal speed signal. maybe other ecu's react differently
Guest S T  E Y E
but if u have a 180 speedo and u get rid of the cut then wont u just either snap the speedo needle or strip the drive cos its hits the dash not long after 180
Nope, won't damage the speedo needle. It just sits against the "stop" until you drop back below 180kph. AFAIK they aren't directly driven but work off magnetism? So no direct mechanical link between the speedo drive and the needle itself.
