structural damage
hey guys just checked up a on carjam came up with structural damage.
Carjam says yes to damage but AA says no ? :-\
which is more reliable ?
and what is "structural" damage?
 Spec C said:
i like my cars with no damge history at all to the body or chaasis , bumpers ok but metal and roofs no
That's not entirely sensible... for example my door got damaged by some numpty in a carpark so I replaced the entire door with a mint one... I didn't want any bog etc. either but if it's done like that, what's the harm?
 1989RS said:
could have failed a warrent because of sill damage and that might have been noted down but it would have to have been fixed before you passed the warrent so you shouldn't really have to worry
has the car been jacked up recently to change mags of springs or struts as this is more common than you'd think.
yeah it depends how bad the sill damage is... if its a big dent in the sill itself then it will definitely fail a wof as a vehicle's sill is known to be one of the the strongest part of the vehicle.
Cars that come into work with sill damage will be refered to a panel beater down the road for a quick examination..if he gives the clear then we carry on with our WOF inspection
if the sills so strong why does it get munted so easy ? :D
carjam will list status when imported , carjam wont list wof fail items
So it was imported damged, repaired and had an AA check which wont find much in real terms anyway
its picked up on the wharf and/or at compliance when the interior is stripped out
The car is "flagged" as having had major repairs / or needs major repairs
When a car that has had pervious repairs the car then goes to a repair certifier, who does a 3d measure and assess the extent / quality of the repair
Sometime the repair will be checked by grinding of paint / bog etc - this is when it gets costly
if it need major repairs, then the repair certifier - will state how the car is to be fixed and signs of the repair once done (he may also need to check during the repair)
Either way the car is "marked" permenantly on the LTSA system as being imported damaged
 Spec C said:
whats a v10 worth on the market?
surely you would have asked this question before purchasing it? If it was bought on TM then no, you cant still back out and you are legally obliged to go through with the purchase.
YES I IS HERE!
My main point is that this car will ALWAYS have the stigma of being "imported damaged" attached to it. Cars that are damaged here and repaired do not have this and are undetectable if done well.
I know as when we traded the mrs previous car in I discovered this and went nato at the dealer who sold it to her unknowing of the history.
