AFAIK All seats are interchangeable up to Version 11 (1989 Legacy+
WRX's are narrower so you end up sitting closer to center console in Legacy's
and many STI's are lower so you end up sitting higher
there will be corrections but as above all rails share same bolt pattern too
some version rear seats will also fit into your BG5 Wagon
or check here:
 kwi_fozze said:
hey guys, if you were ever wondering what seats fit into a gc8 or forester, check out this thread.
http://www.subaruforester.org/vbulletin/f77/ultimate-subaru-seat-thread-53142/
it has a huge amount of information on the seats, what they fit, heated or not, side airbags etc.
thought it may be of some use...
Guest loren
sold my v6 STi front seats to a guy who put them in a honda.
^^Lmao different?^^
Anyone know what seats would do a full swap into my bd5 (sedan legacy 95) and what would keep me sitting at the same height
The all fit fine.... some will require rails as Mine were an integral part of the OEM seat, passenger seat was fine as rails unbolted off it
you may need to swap over the seatbelt buckle/s
I just installed WRX seats into my Forester, directly bolted up, only thing that wasnt the same was the plug for the seatbelt sensor (light that tells you if you havnt buckled up). Otherwise straight swap
Im having a problem undoing the bolt on the passengers seats side closest to the door and closest to the rear seats anyone got any hints or tricks to undo it?
^^^^ be very carefull, let crc soak into it for an hour or so before you give it a go as I have heard (and seen) people break the nut off inside the little housing it sits in which is part of the chassis.... not good, dont over do it just keep the crc up to it untill it budges..
so tonnes of crc?sounds easy all the other bolts are off except this one its anoying Ill sort it out tommorow and let you know how I get on cheers guys
Guest loren
well CRC always helps. breaker bars are a pretty essential tool along with some reinforced hex sockets... but
I wouldn't have thought a reinforced socket would be needed for a seat bolt...
Guest loren
repco have them. probably supercheap too...
I payed about $70 for a power bar at repco in late march/begining of april if that helps
you can get around the need for a power bar by using a length of pipe if you have one lying around. all you need is that extra leverage.
  • 3 months later...
Does anyone know if GDB WRX seats will fit in GC8s? I'm assuming the rails will be different but can you swap the rails around or is it a bit trickier than that?
They fit, i just tried v8 Sti seats in my version 1 on the weekend, it works
Also, just if anyone wants to know, i have my Ver 8 STi seats for sale for who ever might want them?
 RAYDEO said:
My V10 seats fited in my BG GTB and in my V5
THEY WERE A BIT HIGH THO
they bolt stright in
v10 seats into a v5
done and done
    574.7k
