Equal length headers on v7 sti
4 minutes ago, Subru said:
I'm interested to compare equal length vs unequal on stock turbo with no other changes so would it be safe driving it for a few days without a tune touch up?
Then I can do turbo etc just before the tune.
Theoretically there shouldn't be any issue as your total flow is still limited by the factory turbo. if anything the engine should run a little healthier as they've got individual runners a lot further from the port.
I wouldn't worry about driving it before the tune, just don't be a savage on it incase it does introduce a significant change to your engine.
Link to post
Ok. Should definitely be more knock resistant due to equal cylinder Temps etc. Mainly want to see the spool difference so I don't need to go too hard on it to find out. I'm very interested to see what difference it makes.
Link to post
Just so we're clear, I'm NOT certain you will see spool differences when still using a single scroll turbo. When using a twinscroll turbo that's actually made for it, yeah you would.
Link to post
Don't boost it without a dyno check first... you don't know for sure that it won't knock, and that will kill your motor within the blink of an eye.
Edited by Loren
Link to post
Even with just new EL headers?
Link to post
I reckon it'll spool a bit better even twin scroll header to single scroll turbo. I wouldn't be boosting it to much, probably would be fine but not worth risking imo
Link to post
Don't you have a new turbo ?
I reckon it's a coin toss.
The single scroll has the advantage of shorter header pipes on cylinder 1 and 3... that helps spool. Mainly talking about stock unequal length headers here... aftermarket aren't as tight.
The twin scroll have the advantage of no interfering pulses and better flow up top.
Edited by Loren
Link to post
Yeah I have the turbo and few other bits however ill install that just before the tune. Then the tuner will install link ecu and injectors on the dyno.
I would have guessed even pulses would beat having the slightly shorter pipes on two cylinders in terms of spool and power.
Link to post
Chiming in via sound - they sound wicked with Equal length headers. still has the rumble at idle but sound like an imbred evo/wrx on boost its wild. regret not getting them but will look into it shortly once I make up my mind on selling or not haha
Link to post
Yeah I can't wait. Have been listening to some clips including @Lorens car and they definitly sound great. I also have rcm/samco turbo inlet and intake so should get some nice spool nose too.
Link to post
I've finally committed to EL for mine. I'd been tossing up using Niran’s old headers but grabbed a set of EL headers with the same uppipe location to replace the old UEL ones he was running. It's just a more mature sound that doesn't attract the same attention as usual boxer sound.
Link to post
Join the conversation
Reply to this topic...
  Only 75 emoji are allowed.
