Ra models first arrived at the same time as the standard WRX (my93 onwards)- i own 2 of these.
STI RA MODELS first showed up with the V2 models (GC8 C)
Type RA FACTORY FITMENTS/ OPTIONED PARTS
(my system doesnt tell me if it is optioned or as standard)
GC Sedan and Coupe
note - a Type R coupe is known as a WRXSTIRA model Coupe
ROOF VENT
V2- Sedan STI 555 blue
RASTI white
RA STI V LTD- option code 66- 555 blue
V3- Sedan STI 555 blue
RASTI white
V4- Sedan RASTI Blue and White
Coupe WRX RV ltd Blue only
V5- Sedan RASTI blue and white
Coupe option code 75 blue only
V6- Sedan RASTI(3 option codes)White Blue and yellow
Coupe option code 45 blue only
REAR WINDOW WIPER
no Sedan RA models has these as an optioned extra- only came on Sedan STI and WRX models
i would imagine it would be the same for the coupe- but my info doesnt specify
FRONT GUARDS
there were 4 types of guards on the gc. RA models had the same as their non turbo counterparts, while wrx and wrxsti models had their own. 22b guards and gravel express guards were also different. With the infamous "ALLOY GUARDS on the RA models", if they did exist, then they were also fitted to the base model cars too.
MANUAL WINDOWS
All GC chassis Sedan RA and STIRA models had manual windows as standard, except for
V4- Sedan STIRA option 85 and 86
V5- sedan RA option 65 and STIRA option 86
V6- sedan RA option 55 and STIRA option 73 and 83
COUPE models only ever had electric windows (i beleive)
OUTER DOOR HANDLES and WING MIRRORS
RA and STIRA models had unpainted door handles and wing mirrors (ie black) except for
Air Con
was fitted to
WRX RA V1 or 2 option 66
V5 option 55
RA STI V1 or V2 option 61
V5 option 86
V6 option 73 and 83
HEADLIGHTSfrom the Ver 2 onwards, the WRX RA and STI RA models had different headlamp units. this was to accomodate the brighter 12v 100/80w headlight bulbs as they had different mounting lugs
QUICK RACK STEERING
these quick racks were only fitted to STI RA models (and type R coupe) from Ver 3 onwards.
interestingly enough some STI RA models did not have a quick rack
Gearboxes
Front LSD came fitted to
V4 + V5 WRXRASTI option 85 and option 86
V6 WRXRASTI and S201
DCCD came fitted to WRXRASTI and Type R models (V2-V6) and S201 and 22b models
ENGINES
5th INJECTOR ENGINE
these were only ever fitted to RA models as an EJ20G engine. Introduced on the MY93, MY94 and ver 1 and 2 and RA STI ver 1 and Ver 2. They all had the same inlet manifold so theoretically the sti ra models with 5th injector were not painted red
COMPLETE ENGINES
all MY93 engines were closed deck, MY94 manual WRX, RA and STI models got closed deck and MY95 STI and RASTI got closed deck blocks. there were also some other differences
From ver 3 onwards there were only WRX or STI engines, the ra engines werent any different.
and some other parts which i cant think of at the mo.
the above list had been prepared to the best of my knowledge, but may not be perfect.
if this list gives you some concerns as to what your vehicle actually is then check with your local subaru franchise with your chassis number and body model number or pm me
bough to you by Readosnr
  • 3 weeks later...
  • 4 months later...
From memory thats the lightest WRX-RA weight, they vary from there to about 1260 depending on version. Type-R is generally slightly heavier than an STi-RA from the figures I've seen.
I'm also unsure about the quickrack only being available from Ver.3, I've driven a Ver.2 STi-RA V-ltd which had the normal STi quickrack sticker, it certainly flike a pretty quick rack too but I haven't driven a later one to compare.
  • 7 months later...
  • 7 months later...
  • 8 months later...
I am new to WRX as I only bought mine last week. Can anyone help me please. It's a 1998 GC8F 4 DD with option code XNG and a TY754VB1CA gearbox. Car has wind up windows, roof vent, alloy boot lid, R180 diff, quick steering. Car appears to have plate diff fitted to gearbox at some time in its life. (Japan ?)
My question is.. Why do I have AirCon in my car ? And it appears to have had sound deadening material on the floor..is this actually an RA ? I am unsure. Can someone very knowledgeable confirm it is an RA ? Cheers
It'll be getting a Rollcage next month and made into Club Rally car. I am missing quite a few pieces of the car already, but will have rear seats to sell, and some trim from inside.
  • 4 weeks later...
  • 6 months later...
Mine is a v2 sti ra and im sure it has a quick rack steering, is there any way of finding out for sure? It has 1.5 turns lock to lock i think it is
My V4 Type R has rack 34110FA081 and I would say it is ~2.8 turns lock to lock, so probably not a quick rack. Having 1.5 turns lock to lock sounds crazy fast.
    574.7k
