180 km/h speed cut removal
  • Replies 94
  • Created
  • Last Reply
Top Posters In This Topic
 loren said:
and it seems to be a percentage, so if 10% innacurate all the way through... with my STi anyway.
Yeah I'd go with the percentage based accuracy rather than a set km figure. If it was a set figure, then that means that if it's out 10km at 100, it will also be out 10km at 180, but people have found it's more like 15-20km, which leans towards the percentage theory.
EDIT: Sorry, my first explanation made little sense hahaha
 Scoobydoo']
Yeah I'd go with the percentage based accuracy rather than a set km figure. That means that if it's out 10km at 100, it will also be out 10km at 180, but it's more like 15-20km.
what that makes NOOO sense what so ever.
 funkytown']
really, got an explanation?
 funkytown said:
i was pointing out his explanation made no sense - and the OP agreed and changed their post.
Whats your explanation?
well, based on observation, it certainly seems to be a percentage based error... and if the ancient greeks could build a machine to predict lunar and solar eclipses with a high degree of accurancy, out of gears and cogs, I'm sure a modern car manufacturer can make a speedo read 10% wrong.
What's the speed cut based on? My V7 definitely has the '180kmh' speed cut but the needle goes well off the end before it does. So I wonder there's a second, accurate 'speedo' that the car uses internally, while reading ~10% or whatever over on the dash?
 loren']
and i concur - i was just saying the words and logic of his reply - (note: the english words used) not the point of % based error being wrong.
but whatever.
Electronic Speedo's (more so in later model cars) can control the error across the range alot better than an earlier electronic or cable driven speedo.
So, without looking into the logic of the chipset, it could be 10% of given speed, 10% of the span, or even just a set kph at a given speed....
