Dumb Question Thread!
Jambun
 BINKZ said:
Based on this website i would assume i have a 0.9mm pill and need a 1.2mm?? Thoughts?
http://www.type-ra.com/subaru-forum/threads/boost-restrictor-pills.12995/
Nah, 1.2 would net lower boost (Those links are all for the earlier boost solenoid where it works backwards)
try grab a .8mm restrictor, might find you have a 1mm restrictor pill
These boost solenoids work by the less air they get, the more boost. as the way it's fed to the solenoid, The older stuff: it relied on the restrictor to be there to limit boost. so the less restriction = more boost.
Edited by 94 Leone
I had wondered that actually, thanks mate appreciate the explanation :)
 lachlan said:
Who ever put that bonnet scoop on it actually needs to be shot . But yea these exist . Mates gf had a blue one . Was a nice car . Cheap to run and insure and noone will steal it
Nope people still steal them same goes for old gc gf ej15s etc.
 Andy_Mac said:
Ay? The hubs bolted to the knuckle which keeps it 'solid'
The wheel nuts hold the rotor and wheel 'solid' against the hub
Ive pulled the rear axle/hub nut and theres a fair bit of slop now with wheel off. No funny noises when i turn the wheel by hand.
Seems a bit weird for wheel bearings to just go like that though ay.
Mines got a bit of a clunk i'm trying to sus out now too. Sounds like its either the shock knocking or a cv. Seems to have only really come about since doing the rear swaybar which was odd, have gone through and re torqued all the bolts that were undone for the sway. Still have a bit of a sneaking suspicion it may be somehow related to that though
  • Guest locked this topic
