Hey all,
Have been having a few chats with Pat from @PBMS about doing a group order for parts from the US. Pat should be able to give us some competitive pricing on big brands parts, especially if we can get a stack of us to order together. Best time to stack up for those build plans on the boil!
PBMS can get most parts from all major brands. The likes of:
  • Turbosmart
  • Whiteline
  • JE Pistons
  • Harrop Superchargers
  • Kelford Cams
  • Process West
  • Link ECU
  • ECUTEK
  • Emtron
  • ARP
  • Pure Performance Motorsport
  • Invidia
  • King Bearings
  • ACL
  • AEM
  • Aeromotive
  • Garret
  • BorgWarner
  • BC Brian Crower
  • CP
  • Cometic
  • Cusco
  • DBA
  • DW
  • Eagle
  • Exedy
  • GSC Power Division
  • HKS
  • Injector Dynamics
  • Innovate Motorsport
  • KW Suspension
  • Manley
  • OS Giken
  • Perrin
  • Project Mu
  • Radium
  • Rallyarmor (mudflaps)
  • Vibrant
  • Walbro
Basically anything you have had your eyes on, let me know (either PM or comment on here) and i'll collate it all and get us pricing. Send me:
  • Name and brand of the part you want
  • Model no. and qty
Remember the more we get on this the better it will be overall.
Big thanks to @PBMS for supporting the club!
Edited by Niran
  • Like 4
I'll kick us off. I'll most likely be getting:
  1. DBA T3 4000 front and rear rotors
  2. DBA XP+735 pads
For now, plus a stack of other parts if this guy buys my motor.
  2. DBA XP+735 pads
Personal opinion, but I'd buy Dixcel over DBA. More consistency and better wear over time.
Also REALLY good on the track.
Depends on the final price but here’s my list:
Invidia Downpipe Catted Divorced Wastegate w/ 2 Bungs
MODEL # INVHS08SW1DOC
Invidia Uppipe
MODEL # INVHS02SW1UPP
Invidia 3in Downpipe to 2.5in Exhaust Adapter
MODEL # INVHS02SWIAPD
Could also need a 3 port boost control solenoid ( I’ve only found Grimmspeed tho) and a silicone turbo inlet hose.
Can PBMS also do a super special price for tuning (reflash 2011 WRX ecu) after ordering said parts in the group buy? ???
Nice list @Omsin
Will get a full price for you soon
Some suggestions:
- the 3 port, they are all the same. Its a Mac valve. PBMS have link ones which will do the job, or you can try find a mac valve
- don't think changing the silicon inlet hose will do much unless I'm wrong? Better off getting a cold air intake like this:
https://www.rallysportdirect.com/part/cold-air-intakes/aem-21-478wr-aem-cold-air-intake
@Dairusire the price of the dixcel stuff is quite high compared to DBA. Haven't heard of anything negative about the t3 DBAs so keen to give them ago. Also they look dam nice lol. Wanted the dixcel z pads but they are 600+
Will give these DBA ones a go and report back
Forgot
JE pro seal fire ring head gaskets
PS I have XP pads and I don’t like them. Not great initial bite and feel soft when braking. Soft is not pedal feel but more weak braking performance. They still stop ok but not aggressive enough for me.
told they can be worn out after maybe two track days.
the T3 discs seem fine
DBA1678XP fronts
DBA1521XP rears
Old ones were Bendix street road track which felt more confident and solid.
they both squeak and squeal though.
I found EBC to be really good before.
They don’t make the pads I had anymore but it sat between orange and blue. Pretty much orange but higher temp range.
Ps if you think you may go to new motor then get better pads.
Edited by Gripless
Put me down for these, assuming the prices are favourable compared to sourcing ourselves.
Link MAP4
Emtron ELC1
Perrin alt cover PSP-ENG-150BK
Should probably grab a stronger clutch too, not sure what the Exedy HD’s are rated to.
On 28 September 2019 at 12:40 AM, Gripless said:
Forgot
Do they require block machining? I've been looking into The Athena ones! But haven't committed yet.
& does the block require machining for the RCM 14mm-12mm head studs? Probably kill a few birds at a time?
Athena is JE, same parent company
14/12 mm require only block to have new threads drilled and cut. Heads stay stock.
with any other big studs you have to drill the holes in the head bigger.
only WRC style seperate inconel rings need the groove machines in.
Athena and JE have a ring inside the gasket and no extra work required
I've got Athena fire ring ones on the way for mine already. Think they're coming from speedfactor. Quite a long lead time to get them into the country though.
6 minutes ago, Andy_Mac said:
I've got Athena ring ones on the way for mine already. Think they're coming from speedfactor. Quite a long lead time to get them into the country.
Yeah that's where I was looking! Do you know the thicknesses?
Pretty sure I'm after 1.6mm
