Put My RS in the shed up on axle stands and Linda and i began removing gearbox and diff in preparation for V3RA DCCD box and diff conversion..
BTW.. Found a good way to not get smelly gearbox oil on your hands....
Just get Linda to remove the drain bung!!!!
I dropped the bung last time i removed it. and had to go fishing in the bucket...
Linda had hands of gold!!!!
Guest boostcut
you mean bastard... why not give her diff or diesel engine oil...
Does anyone want a cash job to finish off the headunit and amp/subs in my RS?
Cash paid!
Need it done asap, can travel.
I had it all wired up but got no sound, bypassed the factory macintosh amp but still no sound,
so needs someone good with them!
well heres my **** of things ive done yeday and today..
I must say a MASSIVE shout out to Keltik and Paul (scooby) for the help last weekend putting the box on - total mission! they were awesome giving me a hand - and bleeding all my brakes.
Keltik also 3/4's wired up my DCCD...
so thanks lads - heres my list of things i trucked on with
Things to buy
30 Clutch Slave bolt
31 Redline Shockproof 80w/140 Gear Oil
32 Relay
33 Gear Stabalizer
34 trans cooler line
35 5mt speedo holder thingy
36 Engine Oil
37 Vac hose for breather
38 Long funnel
Tasks to complete
2 Collect nut for clutch slave
3 buy Gear shifter Stabalizer
4 buy trans cooler pipe
6 Collect Tail shaft
8 Fit breather hose for GB
9 Bolt on starter motor
13 Bolt on stabaliser
19 Fit Rear seats
20 Fit Speedo holder thingy
7 Bolt on Turbo
14 Mount Gear Linkage
15 Reinstall intake
12 Fix intercooler piping
10 Fix seals in front axles
11 install front axles
21 install front pipe
23 install mid and rear section zhorst
18 Fix B Pillar Brace
22 install K Frame
5 Fill Box with gear Oil
1 Fill the rear diff
43 Bleed Powersteering and replaced seals
I r beens busy
Guest boostin
Use the back bolt from the A/C - alternator bracket for the clutch slave (the one between the bracket and the intake manifold).
I think i broke my input shaft bearings. After a spirited drive just off the limiter in 5th for ~10k's (on a closed private road) It makes a rattly whirring noise in neutral now. Goes away with the clutch in.
Also nearly put a gearbox through my rear window. Wasnt very secure after all EJ20T :P
The carputer also died after i hit a bump on the matata straights. Turned out the power cord fell out, and there i was panicking!
Guest boostcut
so thats the meaning of panic at the disco (in keltiks wagon)
Finally filled up the gearbox with fluid and fixed some other minor issues, took her for a cautious drive round the block testing that everything was alright, which it was so took her for a wee strop out in the woods, much happier as a 4wd.
sounds like you had your foot resting on the clutch for that 10k and cooked the thrust/release bearing
does it make that sound while driving? is more like a chattering noise?
Hope It didn't scratch your car Kelt...
Your Box doesn't sound good dude......
 jacsmiley']
[quote name='keltik said:
I think i broke my input shaft bearings. After a spirited drive just off the limiter in 5th for ~10k's (on a closed private road) It makes a rattly whirring noise in neutral now. Goes away with the clutch in./quote]
Na.. Won't be that with Kelt. That boy can drive!...
If you only knew what that poor gearbox has been through.... LOL!!!
I found an ingenious method of securing it and will pass on this knowledge when you come to pick it up!
Nope not a release bearing, I use my foot-rest for resting my foot and my clutch pedal for making the tires squeel.
